GA22FC image number 0
GA22FC image number 1
GA22FC image number 2
GA22FC image number 3
GA22FC image number 4
GA22FC image number 5
GA22FC
GA22FC
GA22FC
GA22FC
GA22FC
GA22FC
Your Everyday Work and Play Companion
GA22FC
The GA22FC is designed for office workers and gamers alike who want to enjoy a seamless and leveled-up everyday experience.
With a 21.45” FHD display, 4000:1 high contrast ratio, and a 100Hz refresh rate, the GA22FC meets the needs of both light esports and daily work. It is the perfect choice for an entry-level display with high-value performance.
  • In Stock
€ 79,99
Workers and Players Unite
The GA22FC has been crafted as a daily workhouse and
companion for gaming, working, and entertainment.
It offers several visual modes such as Act, FPS, RTS, User,
Standard, Web, Text, and Movie, as well as Adaptive Sync
for smooth and tear-free visuals. These numerous options
provide users of all kinds with the flexibility they need to
get anything done.
EXPERIENCE BETTER GAMING SESSIONS
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
All-Day Comfort
A low blue light display mode reduces the amount of potentially harmful blue light, while a flicker-free function provides a stable display, putting your mind at ease during long sessions.
MULTIPLE CONNECTIONS
Connect your devices with I/O ports consisting of:
• HDMI 1.4
• VGA
• Power
  • Product Number CMI-GA22FC
  • Screen Size 21.45"
  • Ratio 16:9
  • Screen Type Flat Series
  • Panel VA 16.7M
  • Resolution FHD 1920x1080
  • Refresh Rate 100 Hz
  • Contrast Ratio 4000:1
  • Brightness 250 nits (Typical)
  • HDR N/A
  • HDR Peak Brightness N/A
  • Dimming Zones N/A
  • Color Gamut sRGB 105% (Typ., CIE 1931)
  • Color Gamut DCI-P3 75% (Typ., CIE 1976)
  • Color Gamut Adobe RGB 73% (Typ., CIE 1931)
  • I/O - VGA 1
  • I/O - HDMI 1.4 1
  • Overdrive Technology Yes
  • Response Time 4ms (GtG)
  • Response Time 1ms (MPRT)
  • Eye Protection Low Blue Light (S/W)
  • Anti-flicker N/A
  • I/O - Speaker N/A
  • KVM N/A
  • PIP/PBP (Screen Split) N/A
  • Power Consumption 24W (Max)
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment N/A
  • Height Adjustment N/A
  • Pivot Adjustment N/A
  • Cooler Master Enhanced Cooling Design N/A
  • Monitor Series GA Series
  • Product Gaming Monitor
  • Panel Type VA
