GA2501 image number 0
GA2501 image number 1
GA2501 image number 2
GA2501 image number 3
GA2501 image number 4
GA2501 image number 5
GA2501 image number 6
GA2501 image number 7
GA2501 image number 8
GA2501 image number 9
GA2501 image number 10
GA2501 image number 11
GA2501 image number 12
GA2501
GA2501
GA2501
GA2501
GA2501
GA2501
GA2501
GA2501
GA2501
GA2501
GA2501
GA2501
GA2501
Dive Into The Gaming World
GA2501
GA2501 is a 24.5-inch FHD monitor with 100Hz refresh rate and Adaptive Sync support. With all the necessary features and specifications, the GA2501 is a value-oriented monitor that provides exceptional performance in both gaming and work applications.
  • In Stock
€ 109,99
Experience better gaming sessions
EYE-FRIENDLY LOW BLUE LIGHT AND FLICKER FREE
  • Product Number CMI-GA2501
  • Screen Size 24.5"
  • Ratio 16:9
  • Screen Type Flat Series
  • Panel IPS 16.7M (6 bit + FRC)
  • Resolution FHD 1920x1080
  • Refresh Rate 100 Hz
  • Contrast Ratio 1300:1
  • Brightness 250 nits (Typical)
  • HDR N/A
  • HDR Peak Brightness N/A
  • Dimming Zones N/A
  • Color Gamut DCI-P3 84% (Typ., CIE 1976), Adobe RGB 84% (Typ., CIE 1931), sRGB 109% (Typ., CIE 1931)
  • I/O - VGA 1
  • I/O - HDMI 1.4 1
  • I/O - 3.5mm Audio Out 1
  • Overdrive Technology Yes
  • Response Time 1ms (MPRT), 4ms (GtG)
  • Eye Protection Low Blue Light (S/W)
  • Anti-flicker Yes
  • Power Consumption 24W (Max)
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment N/A
  • Height Adjustment N/A
  • Pivot Adjustment N/A
  • Cooler Master Enhanced Cooling Design N/A
  • Monitor Series GA Series
  • Product Gaming Monitor
  • Panel Type IPS
