GA2701S image number 0
GA2701S image number 1
GA2701S image number 2
GA2701S image number 3
GA2701S image number 4
GA2701S image number 5
GA2701S image number 6
GA2701S image number 7
GA2701S
GA2701S
GA2701S
GA2701S
GA2701S
GA2701S
GA2701S
GA2701S
Dive Into The Gaming World
GA2701S
GA2701S is a 27-inch FHD monitor with 100Hz refresh rate and Adaptive Sync support. With all the necessary features and specifications, the GA2701S is a value-oriented monitor that provides exceptional performance in both gaming and work applications.
  • In Stock
€ 119,99
ADAPTIVE SYNC
ADAPTIVE SYNC
Experience better gaming sessions. The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
LOW BLUE LIGHT AND FLICKER FREE
GA2701S is flicker free and has a low blue light mode to further protect your eyes from potentially harmful blue light emissions.
VIVID COLOR DISPLAY 95% SRGB
Covering 95% of the sRGB color gamut, this monitor delivers optimal color detail, making it suitable for color-sensitive tasks.
IPS BRILLIANCE 1000:1 CONTRAST RATIO
At a 1000:1 contrast ratio, the IPS panel provides a vibrant visual experience, whether you're gaming, working or streaming content.
MINIMALISTIC AESTHETIC
GA2701S sticks to the basics a with a no-nonsense design focusing on a minimalistic aesthetic. The clean design is sure to seamlessly fit into your work and play setup.
 CONNECTIVITY OPTIONS
Connect your devices with the I/O ports consisting of:
• HDMI x 1
• VGA x 1
• 3.5mm Headphone Jack x 1
  • Product Number CMI-GA2701S
  • Screen Type Flat Series
  • Ratio 16:9
  • Screen Size 27"
  • Panel IPS 16.7M
  • Resolution FHD 1920x1080
  • Refresh Rate 100 Hz
  • Contrast Ratio 1000:1
  • Brightness 250 nits (Typical)
  • Color Gamut sRGB 95%
  • I/O - VGA 1
  • I/O - HDMI 1
  • I/O - Earphone Out 1
  • Response Time 1ms (MPRT)
  • Eye Protection Low Blue Light (S/W)
  • Anti-flicker Yes
  • Overdrive Technology Yes
  • Power Consumption 21W*
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Note * Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Product Gaming Monitor
  • Monitor Series GA Series
  • Panel Type IPS
