GA271 image number 0
GA271 image number 1
GA271 image number 2
GA271 image number 3
GA271 image number 4
GA271 image number 5
GA271
GA271
GA271
GA271
GA271
GA271
Dive Into The Gaming World
GA271
The GA271 is a WQHD monitor with up to 100Hz refresh rate with Adaptive Sync support. With all the necessary features and specifications, the GA271 is a value-oriented monitor that provides exceptional performance in both gaming and work applications.
  • In Stock
€ 159,99
100Hz refresh rate
DEEPER ENHANCED CONTRAST
GA271's VA panel produces deeper, darker blacks for an enhanced contrast level, leading to higher picture quality. With a 4000:1 contrast ratio, GA271's VA panel is capable of reproducing a contrast level 4x higher than that of a standard IPS panel.
ADAPTIVE SYNC
ADAPTIVE SYNC
GA271 comes with Adaptive Sync support, providing an extra-smooth, tear-free experience in your games. Gain a competitive edge over your opponents with less motion smearing and clearer visuals in the games you play.
LOW BLUE LIGHT AND FLICKER FREE
GA271 is flicker free and has a low blue light mode to further protect your eyes from potentially harmful blue light emissions.
Feature
PICTURE MODES
Choose the picture mode your want for any scenario you may encounter.
Feature
Minimalistic Aesthetic
GA271 sticks to the basics a with a no-nonsense design focusing on a minimalistic aesthetic. The clean design is sure to seamlessly fit into your work and play setup.
  • Product Number CMI-GA271
  • Screen Type Flat Series
  • Ratio 16:9
  • Screen Size 27"
  • Panel VA 1.07B
  • Resolution 2K WQHD 2560x1440
  • Refresh Rate 100 Hz
  • Contrast Ratio 4000:1
  • Brightness 250 nits (Typical)
  • HDR 10
  • Color Gamut sRGB 95%
  • I/O - DP 1
  • I/O - HDMI 2
  • VRR Technology Adaptive Sync, FreeSync Range: Yes, G-Sync Range: Yes
  • Response Time 1ms (MPRT)
  • Anti-flicker Yes
  • Overdrive Technology Yes
  • Power Consumption 18W
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Product Gaming Monitor
  • Monitor Series GA Series
  • Panel Type VA
