GM25FP image number 0
GM25FP image number 1
GM25FP image number 2
GM25FP image number 3
GM25FP image number 4
GM25FP image number 5
GM25FP
GM25FP
GM25FP
GM25FP
GM25FP
GM25FP
Seamless Fusion of Everyday Work and Play
GM25FP
Introducing the GM25FP, a new monitor designed
with high-octane gamers in mind, but suitable for
office workers and casual entertainment as well.
With features such as a 180Hz refresh rate, an IPS
panel and 106% sRGB color, several display modes suited for a variety of activities, and both a low blue light mode and flicker-free functionality.
The GM25FP will take your game life and work life
to the next level.
  • In Stock
€ 129,00
For Gamers and Workers Alike
While the GM25FP has been designed to support next-gen gaming, workers and more casual users will also benefit greatly from its features, such as the many visual modes including Act, FPS, RTS, User, Standard, Web, Text, and HDR. Adaptive Sync is also supported for smooth, tear-free visuals to ensure every user's experience is silky and uninterrupted.
Experience Better Gaming Sessions
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
Comfort Day and Night
A Low Blue Light display mode and flicker-free function ensure the GM25FP remains easy on the eyes, even during extra long sessions.
MULTIPLE CONNECTIONS
Connect your devices with I/O ports consisting of:
• HDMI 2.0 x2
• DisplayPort 1.4 x2
• Power
• Audio Out
  • Product Number CMI-GM25FP
  • Screen Size 24.5"
  • Ratio 16:9
  • Screen Type Flat Series
  • Panel IPS 16.7M (8 Bit)
  • Resolution FHD 1920x1080
  • Refresh Rate 180 Hz
  • Contrast Ratio 1000:1
  • HDR Peak Brightness 250 nits (Typ.)
  • Dimming Zones N/A
  • Color Gamut sRGB 106% (Typ., CIE 1931), DCI-P3 78% (Typ., CIE 1976), Adobe RGB 74% (Typ., CIE 1931)
  • I/O - DP 1.4 1
  • I/O - HDMI 2.0 2
  • I/O - 3.5mm Audio Out 1
  • Overdrive Technology Yes
  • Response Time 1ms (MPRT), 1ms (GtG)
  • Eye Protection Low Blue Light (S/W)
  • Anti-flicker Yes
  • I/O - Speaker N/A
  • KVM N/A
  • PIP/PBP (Screen Split) N/A
  • Lighting N/A
  • Power Consumption 24W (Max)
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+17°
  • Swivel Adjustment N/A
  • Height Adjustment N/A
  • Pivot Adjustment N/A
  • Cooler Master Enhanced Cooling Design N/A
  • Product Gaming Monitor
  • Monitor Series GM Series
  • Panel Type IPS
