Silencio S400 image number 0
Silencio S400 image number 1
Silencio S400 image number 2
Silencio S400 image number 3
Silencio S400 image number 4
Silencio S400 image number 5
Silencio S400 image number 6
Silencio S400 image number 7
Silencio S400 image number 8
Silencio S400 image number 9
Silencio S400 image number 10
Silencio S400 image number 11
Silencio S400 image number 12
Silencio S400 image number 13
Silencio S400 image number 14
Silencio S400 image number 15
Silencio S400 image number 16
Silencio S400 image number 17
Silencio S400 image number 18
Silencio S400 image number 19
Silencio S400 image number 20
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silence Has A Sequel
Silencio S400
Silencio Design
Silencio Technology
Sound Dampening Material
Top & Front Ventilation
Reversible Steel Door
  • In Stock
€ 119,99
Silencio Technology
Front
Ventilation
The front panel features a recurved vent, directing air in through the front bezel. The curve points downward, taking air in from the bottom, and straightens out to direct air in from either side of the steel front door.
Ventilation
Silencio Fans
Silencio Fans
Versatile HDD Cage
The HDD cage is (re)movable. The cage can be shifted forward to make room for a longer PSU, backwards for additional radiator space, or completely removed if HDD storage is not needed.
Versatile HDD Cage
Versatile HDD Cage
Motherboard Support
Mini-ITX, Micro-ATX
Cooling Support
Fans
Radiators
Top:
120 / 140mm x 1 Fans
120 / 140mm x 2 Fans (remove ODD cage)
120 / 240* Radiator
*remove ODD cage
Front:
120 / 140 / 240 / 280* Radiator
*may interfere with HDD mounted below ODD bracket
Rear:
120 x 1 Fan
120 x 1 Radiator
Storage Support
5.25” ODD x 1 (ODD version)
3.5” HDD x 4
2.5” SSD x 4
Clearances
CPU Cooler (Steel): 167mm
CPU Cooler (TG): 166mm
Power Supply:
325mm (w/o front radiator & HDD cage)
140mm (HDD cage in backmost position)
Graphics Card: 319mm
  • Model Number MCS-S400-KN5N-S00 (Steel), MCS-S400-KG5N-S00 (TG)
  • Color(s) Black
  • Materials - Body Steel, Plastic, Sound Absorbing Material
  • Dimensions (L x W x H) 418 x 210 x 408mm (Incl. Protrusions), 403.5 x 210 x 400mm (Excl. Protrusions)
  • Volume 33.9L (excl. Protrusions)
  • Expansion Slots 4
  • 5.25" Drive Bays 1
  • 3.5" Drive Bays 4
  • 2.5" Drive Bays 4
  • I/O Panel - USB Ports 2x USB 3.2 Gen 1 (formerly USB 3.0)
  • I/O Panel - SD Card Reader Supports SD & MMC Cards
  • Pre-installed Fans - Front 1x 120mm (PWM 800-1400 RPM)
  • Pre-installed Fans - Rear 1x 120mm (PWM 800-1400 RPM)
  • Fan Support - Top 1x 120mm, 1x 140mm / 2x 120mm, 2x 140mm (remove ODD cage)
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Front 120 / 140 / 240 / 280mm (remove & reinstall ODD bracket to mount 280mm radiator, may interfere with HDD mounted below ODD bracket)
  • Radiator Support - Top 120 / 240mm* (*240mm requires removal of ODD cage)
  • Clearance - CPU Cooler Steel: 167mm, TG: 166mm
  • Clearance - PSU 325mm (w/o front radiator & drive cage), 140mm (HDD cage in backmost position)
  • Clearance - GFX 319mm
  • Cable Routing 20mm
  • Size Mini Tower
  • Series Silencio Series
