Mobius 120 Black Edition image number 0
Mobius 120 Black Edition image number 1
More Balance, More Burst
Ring blade design
Loop dynamic bearing
Dust protection
Oil reflow system
  • In Stock
€ 14,99
 PERFECTING ENGINEERING
Introducing the latest addition to Cooler Master’s critically-acclaimed Mobius case fan series, the Mobius 120 Black Edition. This version of the Mobius includes all the high-performance features of the classic Mobius, now in a blackout design. With our innovative ring blade design, loop dynamic bearing, oil reflow and anti-sway systems, and dust protection, the Mobius 120 Black is an aesthetically sleek take on a Cooler Master classic.
Pressure Acceleration Air Vents
Angled inner frame rim with chamfered side vents boost airflow draw, The structural ring blade eliminates any fan deformation- Ring Blade keeps the fan build structure rigid, inflexible, stiff and rigor 45 deg Q in and Q out, larger air flow in and air flow out increasing the Q
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
  • Product Number MFZ-M2NK-21NPK-R1
  • Exterior Color Black
  • Fan Profiles Non-LED
  • Fan Speed 0-2050 RPM ± 10%
  • Fan Airflow 63.1 CFM
  • Fan Noise Level 22.6 dBA
  • Fan Air Pressure 2.69 mmH2O
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.12A
  • Fan Safety Current 0.35A
  • Fan Power Consumption 1.44W
  • Fan Weight 168g / 0.37 lbs
  • Warranty 5 years
  • Cooler Type Case Fan
  • Series Mobius Series
  • LED Lighting Non-LED
