Mobius 140 Black Edition image number 0
Mobius 140 Black Edition image number 1
Mobius 140 Black Edition image number 2
More Balance, More Burst
Ring Blade Design
Pressure Air Acceleration
Loop Dynamic Bearing
Dust Protection
Oil Reflow System
  • In Stock
€ 19,99
RING BLADE DESIGN (RBD)
ANTI-VIBRATION DAMPER
PRESSURE AIR ACCELERATION
Angled inner frame rim with chamfered side vents boost airflow draw, maximizing force induced air pressure and diminishing dead air.
LOOP DYNAMIC BEARING
OIL REFLOW SYSTEM
DUST PROOFING
ANTI-SWAY SYSTEM
  • Product Number MFZ-M4NK-19NPK-R1
  • Exterior Color Black
  • Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Fan Profiles Non-LED
  • Fan Speed 0-1900 RPM ± 10%
  • Fan Airflow 76.5 CFM
  • Fan Noise Level 30 dBA
  • Fan Pressure 2.3 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.35A
  • Fan Safety Current 0.4A
  • Fan Power Consumption 4.2W
  • Fan Weight 168g / 0.37 lbs
  • Warranty 5 years
  • Cooler Type Case Fan
  • Series Mobius Series
  • Fan Size 140
  • LED Lighting Non-LED
