ARGB GPU Support Bracket image number 0
ARGB GPU Support Bracket image number 1
ARGB GPU Support Bracket image number 2
ARGB GPU Support Bracket image number 3
ARGB GPU Support Bracket image number 4
ARGB GPU Support Bracket image number 5
Fortify Your GPU
Eliminate Graphics Card Sag
Edge-Lit ARGB Tempered Glass
Easy To Install
Multiple Orientations
Protect Your Components
Versatile Support
  • In Stock
Price reduced from € 29,99 to € 24,99
A New Type of Reinforcement
Tempered glass, addressable RGB, and edge-lighting technology all crammed into a not-so-simple graphics card support bracket.  Sure, GPU brackets are an important tool in keeping your motherboard’s PCI-e slot safe from sag but we bet you didn’t expect it to be the new centerpiece to your build.
The MasterAccessory ARGB GPU Support Bracket utilizes the strength and aesthetic of tempered glass in completely new ways. The strength of the TG supports the biggest, baddest cards out there. The CNC machining provides edge-lit ARGB. The universal design of the support arm offers hassle-free adjustment, by sliding and locking in place, to fit a high range of graphics card and PC case combinations. If your build is on the subtler side, switch off the lighting for an elegant, invisible GPU support bracket.
Equal parts functional and artistic, the MasterAccessory ARGB GPU Support Bracket keeps your PCI-e slots safe as effectively as it keeps you staring at your glorious build for way too long.
As graphics cards become larger and heavier, PCI-e slots suffer from increased stress and weight. The MasterAccessory ARGB GPU Support Bracket eliminates this by supporting the GPU’s weight-critical points.
Easy to Install
Edge-lit ARGB Tempered Glass
CNC machining on the tempered glass creates rails for ARGB lighting to travel throughout the bracket. The lighting can also be turned off for a near-invisible aesthetic.
Versatile Support
  • Model Number MCA-U000R-GSBTG-00
  • Color(s) Black
  • Materials - Exterior ABS Plastic, Tempered Glass
  • Dimensions (L x W x H) 58 x 58 x 177mm / 2.29 x 2.29 x 6.97inch (Incl. Protrusions)
  • ARGB Cable length 510mm/20.1inch
  • Included GPU supports 2
  • ARGB Controller Not Included
  • Gross Weight 0.22 kg / pcs
  • Net Weight 0.14 kg / pcs
  • Series Others
