Caliber R3C Gaming Chair image number 0
Caliber R3C Gaming Chair image number 1
Caliber R3C Gaming Chair image number 2
Caliber R3C Gaming Chair image number 3
Caliber R3C Gaming Chair image number 4
Polar Ice Expedition
The Next-level in Cooling Tech
Introducing Cooler Master's Coolin Series: Ice-cool in white, grey accents. R3C, the timeless gaming chair for cool comfort in every game.
  • In Stock
€ 299,00
STAY COOL WHILE YOU WORK & PLAY
Discover R3C in Storm Grey or Polar White—perfectly complementing your setup with timeless style and cool comfort.
CHOOSE YOUR SIDE
CHOOSE YOUR SIDE
Will you join the light or dark side of Caliber’s R3C colors?
Gaming Chair
COOL-IN TECH
Caliber R3C feels 1-2°C cooler than a regular gaming chair. COOL-IN Fabric Technology enhances the overall comfort of your workstation by reducing chair-to-player heat exchange and humidity accumulation, which leads to more sweat build-up during long hours of gameplay.
THE COOLING EFFECT
Gaming Chair
SUPERIOR DURABILITY
CAT SCRATCH-PROOF
The COOL-IN Fabric Tech also provides extra benefits of cat scratch-proof and a dust repellent and easy-to-clean surface for daily usages.
FORMALDEHYDE FREE
The COOL-IN fabric is made from formaldehyde-free materials. It is suitable for environmentally sensitive areas and everyone who wants to enjoy a healthy gaming experience.
  • Product Number CMI-GCR3C-BK, CMI-GCR3C-GW
  • Color Black / Gray & White
  • Total Height Range 125.5-133.5 cm / 49.4"-52.6"
  • Backrest Height 82 cm / 32.3"
  • Backrest Width 58 cm / 22.8"
  • Armrest to Armrest 71 cm / 28.0"
  • Seat Width (including sides) 58 cm / 22.8"
  • Sitting Area 38 cm / 15.0"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 70 cm / 27.6"
  • Seat Thickness 10.5 cm / 4.1"
  • Armrest Adjustability 28.5-36.5 cm / 11.2"-14.4"
  • Floor to Seat Top 48-56 cm / 18.9"-22.0"
  • Height Adjustability 8 cm / 3.1"
  • Recline 90-180 degree
  • Armrest 2D
  • Headrest Ultra-comfortable memory foam
  • Lumbar Support Ultra-comfortable memory foam
  • Outer Material Eco-friendly Cooling & Cat scratch-proof fabric (Non-toxic polyester) on front
  • Inner Material Backrest: cut foam, Seatbase: cold molded foam
  • Frame Material Steel
  • Base (leg) Steel
  • Caster 60 mm / 2.4"
  • Gas Lift Class 4
  • Max. Weight Load 150 kg / 330 lbs
  • Chair Type Cooling Series
  • Chair Type Caliber R3 Series
  • Product Gaming Chair
