Caliber X2C Gaming Chair image number 0
Caliber X2C Gaming Chair image number 1
Caliber X2C Gaming Chair image number 2
Caliber X2C Gaming Chair image number 3
Caliber X2C Gaming Chair image number 4
Polar Ice Expedition
Get ready to One Hit Knock-out (OHKO) the competition from the comfort of your breezy Caliber X2C!
Price reduced from € 399,99 to € 389,99
MADE FOR WORK & PLAY
Race towards the future or chase your dreams - the X2C chair makes for the best companion. Stunning to look at with comfort and support at its finest.
 COOL-IN TECH
COOL-IN TECH
Caliber X2C feels 1-2°C cooler than a regular gaming chair. COOL-IN Technology enhances the overall comfortability of your workstation by reducing chair-to-player heat exchange and humidity build-up, which lead to sweatiness during long hours of gameplay.
 THE COOLING EFFECT
THE COOLING EFFECT
COOL-IN Fabric Technology provides efficient cooling by extracting hot air from the body, passing it through the COOL-IN Fabric which helps mitigating hot temperatures by exhaling cool and dry air back onto the seat surface. this helps reduce body heat and allows sweat evaporation, heat convection, and makes your body feel cooler and dry.
Superior Durability
FORMALDEHYDE FREE
The COOL-IN fabric is made from formaldehyde-free material. It is suitable for environmentally sensitive areas and everyone who wants to enjoy a healthy gaming experience.
Cat Scratch-proof
The COOL-IN Fabric Technology also provide extra benefits of cat scratch-proof and a dust repellent and easy-to-clean surface for daily usages.
  • Product Number CMI-GCX2C-BK, CMI-GCX2C-GW
  • Color Black / Gray & White
  • Total Height Range 130-138 cm / 51.2"-54.3"
  • Backrest Height 86 cm / 33.9"
  • Backrest Width 58 cm / 22.8"
  • Armrest to Armrest 72 cm / 28.3"
  • Seat Width (including sides) 54 cm / 21.3"
  • Sitting Area 54 cm / 21.3"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 70 cm / 27.6"
  • Seat Thickness 11.5 cm / 4.5"
  • Armrest Adjustability 30-37 cm / 11.8"-14.6"
  • Floor to Seat Top 50-58 cm / 19.7"-22.8"
  • Height Adjustability 8 cm / 3.1"
  • Armrest Width Adjustability 1.5 cm / 0.6"
  • Recline 90-180 degree
  • Armrest 4D (lift, sway, swivel, forward)
  • Headrest Ultra-comfortable memory foam
  • Lumbar Support Ultra-comfortable memory foam
  • Outer Material Eco-friendly Cooling & Cat scratch-proof fabric on the front
  • Inner Material Cold molded foam
  • Frame Material Steel
  • Base (leg) Aluminum
  • Caster 75 mm / 3.0"
  • Gas Lift Class 4
  • Max. Weight Load 150 kg / 330 lbs
  • Product Gaming Chair
  • Chair Type Caliber X2 Series
  • Chair Type Cooling Series
