CryoFuze 7 image number 0
CryoFuze 7 image number 1
CryoFuze 7 image number 2
CryoFuze 7 image number 3
CryoFuze 7 image number 4
CryoFuze 7
CryoFuze 7
CryoFuze 7
CryoFuze 7
CryoFuze 7
Close Cold Contact
CryoFuze 7
Noncorrosive Formula
Low Thermal Impedance
Anhygroscopic Composition
Eco-Friendly Packaging
  • In Stock
Price reduced from € 9,99 to € 7,99
High Performance
Utilizing nanoparticles, CryoFuze allows for excellent thermal conductivity on all processing components for optimal heat transfer.
With thermal impedance of 0.03C*cm2/w, CryoFuze 7 greatly improves overall performance
Non Corrosive Formula
CryoFuze 7 also has a versatile range of temperature performance, maintaining stability from -50°C up to 250°C. All of this is contained in an eco-friendly, environment-first package.
Easy Application
Viscously balanced formula allow for easy application and clean up.
ECO-FRIENDLY PACKAGING
Designed with the environment in mind, CryoFuze 7’s packaging reduces waste
  • Product Number MGZ-NDSG-N04G-R1 (4g), MGZ-NDSG-N07M-R2 (2g)
  • Color Gray
  • Thermal Impedance 0.03 °C*in²/W
  • Specific Gravity 2.7 (25°C)
  • Weight 4 g
  • Scraper Yes
  • Grease Cleaner Yes
  • Series Cryofuze Series
