ERGOSTAND IV image number 0
ERGOSTAND IV image number 1
ERGOSTAND IV
ERGOSTAND IV
SIMPLE YET POWERFUL
ERGOSTAND IV
Ergonomic design
Full Mesh Board
Silent Cooling
LED Strip & Additional USB Hub
  • In Stock
€ 42,99
Ergonomic Design
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
Full Mesh Board
The use of full mesh board improves its cooling performance greatly.
Led Strip & Additional USB Hub
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
Silent Cooling
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
  • Product Number R9-NBS-E42K-GP
  • Color Black
  • Material Metal Mesh, Plastic, Rubber
  • Strip LED Blue
  • Dimensions (L x W x H) 370 x 265 x 40 mm
  • Fan Dimensions (L x W x H) 140 x 140 x 15 mm / 5.5 x 5.5 x 0.6 inch
  • Fan Speed 700–1400 RPM ± 150
  • Fan Airflow 46.8 CFM ± 10%
  • Fan Air Pressure 1.24 mmH2O
  • Fan Noise Level 29 dBA (Max)
  • Power USB 5V DC
  • USB USB 2.0 x 4, Mini x 1, Micro x 1
  • Current Consumption 0.20A
  • Power Consumption 1.0W
  • Compatibility Supports up to 17" laptops
  • Cooler Type Notebook Cooler
  • Series Ergostand
