G Gold 750 V2 image number 0
G Gold 750 V2 image number 1
G Gold 750 V2
G Gold 750 V2
Power Evolved
G Gold 750 V2
ATX 3.1 Support
High Temperature Resilience
Quiet HDB Fan
80 Plus Gold Certified Efficiency
Embossed Cable
5-year Warranty
  • In Stock
Price reduced from € 109,99 to € 94,99
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, the 750W unit is optimized for ideal compatibility with 40 series GPUs.
Embossed Cable
Quiet HDB Fan​
Exceptional Efficiency
The G Gold V2 is certified to achieve more than 90% efficiency at typical loads.​​
  • Model MPE-7502-ACAAG
  • Input Current 10-6A
  • Fan Bearing HDB
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time >16ms
  • SATA Connectors 6
  • PCI-e 6+2 Pin Connectors 4
  • Warranty 5 Years
  • Series G Series
  • 80 Plus Efficiency Gold
  • Modular Non Modular
  • Category 500 to 750W
  • Watts 750W
