GP57ZS image number 0
GP57ZS image number 1
GP57ZS image number 2
GP57ZS image number 3
GP57ZS
GP57ZS
GP57ZS
GP57ZS
Embark on a Boundless Immersive Journey
GP57ZS
  • In Stock
€ 2.168,39
Embark On a Boundless Immersive Journey
Introducing Cooler Master’s GP57ZS, our latest high-performance curved monitor made to surround and envelop you in whatever visual experience you please whether it be for work or play. Cooler's Master innovative designs can be seen in the aesthetic presentation of the GP57ZS, as well as in the custom heat sink and sound effect, which provide extreme immersion for anything from movies to a serious racing game set up. The super-large screen is also great for workers who need extra space for multi-tasking. The GP57ZS will take you and your PC to another world, all thanks to Cooler Master's design expertise and focus on immersive experiences.
Sharper Than a Razor's Edge
With DUHD resolution, the GP57ZS provides a whole new world in a super sharp visual experience that will make you wonder what is real and what isn't.
The Ultimate In Immersive Entertainment
The GP57ZS features a massive 57 inches of display area with a 1000R curve. The display area surrounds and encompasses you, taking you away from your reality and into whichever world you choose. Whether you are watching an action-packed film fit for a big screen or you've got a racing wheel and full set up to put the petal to the metal, the GP57ZS will take you all the way.
Delicately Displayed
The GP57ZS utilizes VA mini-LED tech for improved HDR and highly delicate visuals, while a dual 4K resolution keeps every image on screen looking ultra-crisp, ensuring that no blurring or smudging will take you out of any experience. Whether you are a movie lover immerse in the thrilling storylines or a gamer trying to make every shot count, the GP57ZS will provide you with the clarity you need.
KVM
Switcher
Easily Breeze Through Daily Work And Play
Innovative Designs
Smooth Like Butter
Smooth Like Butter
At 1ms GTG response time and 120Hz refresh rate,
the GP57ZS ensures butter-smooth visuals
without a single hitch so you can play worry-free.
Experience Better Gaming Sessions
The AMD FreeSync Premium feature ensures smooth visuals, even when the frame rate fluctuates.
Elite Color Accuracy
With extensive color gamut support,
including DCI-P3 98%,
the GP57ZS is ideal for color-critical tasks.
EASY ON THE EYES
With a Low Blue Light mode and Flicker Free support,
you will never have to worry about eye strain as you game,
or work, late into the night.
MULTIPLE CONNECTIONS
Connect your devices with the following ports:
• USB 3.2 Hub x1
• USB Type B x1
• HDMI 2.1 ×2
• DP 1.4 x1
• USB Type C (90W PD) x1
• 3.5 mm Audio Out x1
  • Product Number CMI-GP57ZS
  • Screen Size 57"
  • Ratio 32:9
  • Screen Type Curved Series
  • Curve 1000R
  • Panel VA 1.07B (8 Bit+FRC)
  • Refresh Rate 120 Hz
  • Contrast Ratio 3000:1
  • Brightness 400 nits
  • HDR Peak Brightness 1000 nits
  • HDR 1000
  • HDR Peak Brightness 1100 nits
  • Dimming Zones Mini LED 2304 zones
  • Color Gamut DCI-P3 98% (Typ. CIE 1976), sRGB 99% (Typ. CIE 1931)
  • I/O - DP 1.4 1
  • I/O - HDMI 2.1 2
  • I/O - USB Type C 1 (PD 90W)
  • I/O - USB 3.2 Hub 1 (1U4D)
  • I/O - 3.5mm Audio Out 1
  • Overdrive Technology Yes
  • VRR Technology AMD FreeSync Premium
  • Response Time 1ms (MPRT), 1ms (GtG)
  • Eye Protection Low Blue Light (S/W)
  • Anti-flicker Yes
  • I/O - Speaker 2 (10W)
  • KVM Yes
  • PIP/PBP (Screen Split) Yes
  • Lighting Yes
  • Power Consumption 485W (Max)
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment ±30°
  • Height Adjustment 110mm
  • Pivot Adjustment N/A
  • Cooler Master Enhanced Cooling Design N/A
  • Product Gaming Monitor
  • Monitor Series GP Series
  • Panel Type VA
