Hyper 212 Spectrum V3 image number 0
Hyper 212 Spectrum V3 image number 1
Hyper 212 Spectrum V3 image number 2
Cooler Master is releasing the Hyper 212 Spectrum V3, a redesigned addition to its popular 212 Spectrum predecessor.
  • In Stock
€ 34,99
Direct contact technology
4 heat pipes with direct contact ensure more efficient heat transfer from the CPU to the cooler, enhancing cooling performance.
SPECTRUM ARGB FAN
Performance spectrum fan with ARGB compatibility with Asus Aura, ASRock RGB, Gigabyte and MSI RGB motherboards.
NICKEL PLATED HEAT PIPES
4 heat pipes with silver nickel plated finish provide exceptional cooling and aesthetics
UPGRADED INSTALLATION BRACKETS
Redesigned brackets simplify installation on the latest available platforms
CPU COMPATIBILITY
CPU COMPATIBILITY
Learn More
  • Product Number RR-S4NA-17PA-R1
  • Exterior Color Silver
  • Dimensions (L x W x H) 124 x 73 x 152 mm / 4.8 x 2.8 x 5.9 inch
  • Heat Sink Material 4 Heat Pipes / Aluminum Fins
  • Fan Dimensions (L x W x H) 120 x 120 x 25mm
  • Fan Quantity 1 PC
  • Fan Speed 650-1750 RPM ± 10%
  • Fan Airflow 71.93 CFM (Max)
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.26A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 3.12W
  • Cooler Type Air Cooler
  • Series Hyper
  • Heatpipes 4
