MasterLiquid 240L Core ARGB image number 0
MasterLiquid 240L Core ARGB image number 1
Cooler Master has built upon the classic MasterLiquid L Series to present a redesigned and improved release of the MasterLiquid L Core ARGB. Featuring new design elements that bring a classic minimalist look to the series, the MasterLiquid L Core ARGB represents Cooler Master’s ongoing innovative spirit.
Price reduced from € 89,00 to € 75,00
CLEAN CLASSIC DESIGN
Clean minimalist design brings a refreshed modern facelift to the pump cover.
CRYOFUZE THERMAL PASTE
Includes premium CryoFuze thermal paste for exceptional heat conductivity.
Gen S Dual Chamber Pump
Redesigned copper base targets heat spots with precision along with boosted water flow and pressure for enhanced cooling performance.
Expanded Radiator Surface
120mm ARGB Fans
Upgraded 120mm ARGB fans deliver optimal radiator performance and versatile lighting options.
CPU COMPATIBILITY
CPU COMPATIBILITY
Learn More
  • Product Number MLW-D24M-A18PZ-R1
  • Exterior Color Black
  • CPU Socket AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket
  • Radiator Material Aluminum
  • Radiator Dimensions 277 x 119.6 x 27.2 mm / 10.9 x 4.7 x 1.1 inch
  • Pump Dimensions 81 x 76 x 47 mm / 3.2 x 3 x 1.9 inch
  • Pump MTTF >70,000 Hours
  • Pump Noise Level 12 dBA (Max)
  • Pump Connector 3-Pin
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 3.96W
  • Fan Quantity 2 PCS
  • Fan LED Type ARGB
  • Fan Speed 650-1750 RPM ± 10%
  • Fan Airflow 71.93 CFM (Max)
  • Fan Pressure 1.86 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.26A
  • Fan Safety Current 0.37A
  • RAM Clearance N/A
  • Warranty 3 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid Lite
  • Radiator Size 240
