MF120 Lite image number 0
MF120 Lite image number 1
MF120 Lite image number 2
MF120 Lite
MF120 Lite
MF120 Lite
MF120 Lite
  • In Stock
€ 6,99
Cooler Master's MF120 Lite is the ultimate all-in-one fan solution for your PC case. It features a reinforced PBT frame for increased stability and is equipped with balanced fan blades that deliver high airflow and excellent cooling performance.
Its flexible anti-vibration mounting system effectively reduces noise, making it an efficient and quiet choice.
Ultimate All In One Fan Solution
Air Pressure (Max) : 2mmH2O
Fan Speed (Max): 1750 RPM
Fan Noise Level (Max) : 30dB(A)
Fan Airflow : 70.5 CFM
