Global headquarters
More Balance, More Burst
Ring Blade Design
Fan Speed Toggle
Metal Motor Hub
Double Ball Bearing
Lifetime Warranty
Premium Anti-Vibration Dampers
Integrated fan speeds toggle built into the cable let you conveniently adjust fan speeds from 1500rpm up to 3200rpm.
Double Ball Bearings reduces friction to a minimum for silence and extended lifespan.
Patented corner mount design dampen vibration and rattling while maintaining chassis stability for silent operation.
Motor hub constructed of metal for additional stability and reinforcement for extended superior fan performance.
