MWE Gold 1250 - V2 ATX 3.0 image number 0
MWE Gold 1250 - V2 ATX 3.0 image number 1
MWE Gold 1250 - V2 ATX 3.0 image number 2
MWE Gold 1250 - V2 ATX 3.0 image number 3
MWE Gold 1250 - V2 ATX 3.0 image number 4
MWE Gold 1250 - V2 ATX 3.0 image number 5
MWE Gold 1250 - V2 ATX 3.0 image number 6
MWE Gold 1250 - V2 ATX 3.0 image number 7
MWE Gold 1250 - V2 ATX 3.0 image number 8
MWE Gold 1250 - V2 ATX 3.0 image number 9
MWE Gold 1250 - V2 ATX 3.0 image number 10
MWE Gold 1250 - V2 ATX 3.0 image number 11
80 PLUS Gold Efficiency
140mm Silent Fan
High Temperature Resilience
Fully Modular Cabling
10 Year Warranty
region
€ 249,00
 100% ATX 3.0 Compatible
Cooler Master took the initiative and continuously developing our first ATX 3.0 Power Supply lineup. Compliant with ATX 3.0 standard and 12VHPWR connectors, the MWE Gold 1050/1250 - V2 ATX 3.0 can fully support the peak power drawn by the 40 series RTX graphic cards and whole system.
80 PLUS Gold Certified
Efficiency has always been one of the most important factors for users when choosing their power supply unit. While there are a range of efficiency options, 80 PLUS Gold has been the ideal choice for the last several years and continues to be seen as the standard for much of the world. The MWE Gold 1050/1250 - V2 ATX 3.0 features 80 PLUS Gold certification, guaranteeing 90% efficiency at typical load.
Quiet Cooling
Quiet Cooling
The MWE Gold 1050/1250 - V2 ATX 3.0 has been optimized with an 140mm fan along with an advanced fluid-dynamic bearing (FDB) delivers quiet and effective cooling with a long lifespan. With Smart Thermal Control System (STCM), the fan will not spin until at 40% of rated output power to reduce noise.
The MWE Gold 1050/1250 - V2 ATX 3.0 has improved to operate safely at up to 50 degrees Celsius ambient for high-end computer, overclocking and other high intensity applications. Such a high threshold greatly enhances the performance of your PSU and your system.
The fully modular version of the MWE Gold 1050/1250 - V2 ATX 3.0 comes with a set of flat black cables that can be customized to each user's individual needs. It's designed for easy cable management that each system only needs to include the cables required. This unused space within the chassis allows for reduced clutter, better airflow and aesthetic, thereby improving your system's overall cooling.
  • Model MPE-C501-AFCAG-3
  • ATX Version ATX Rev. 3.0
  • Input Current 15-7A
  • Fan Size 140mm
  • Fan Bearing Two Ball Bearing
  • 80 PLUS Rating 80 PLUS Gold
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 3
  • 12VHPWR Connector 1
  • Series MWE Gold Series
  • Category Above 750W
  • 80 Plus Efficiency Gold
  • Watts 1250W
