MWE Gold 850 V2 ATX 3.1 image number 0
MWE Gold 850 V2 ATX 3.1 image number 1
MWE Gold 850 V2 ATX 3.1 image number 2
MWE Gold 850 V2 ATX 3.1 image number 3
Level Up Your Power
ATX 3.1 support
A 90-degree 12V-2x6 adapter cable
High temperature resilience​​
Fully modular cabling
5-year warranty
region
€ 149,99
High Temperature Resilience​
A 50°C operating temperature and high quality Japanese capacitors allow for pushing your machine to the limits.​
Certified Efficiency
The MWE Gold V2 ATX 3.1 is certified to achieve more than 90% efficiency at typical loads.​​
Three 8-pin Connectors
Up to 600W of power is split between three 8-pin connectors, providing enhanced safety.
Fully Modular Cabling
  • Model MPE-8501-AFAAG-3E**
  • Input Current 12-6A
  • Fan Bearing HDB
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time ≥ 16ms
  • Regulatory TUV, CE, CCC, EAC, RCM, cTUVus, FCC, BSMI, BIS, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 4
  • 12V-2x6 Connectors 1 (1 to 3)
  • Category Above 750W
  • Series MWE Gold Series
  • 80 Plus Efficiency Gold
  • Watts 850W
