ORB X - Immersive Station image number 0
ORB X - Immersive Station image number 1
ORB X - Immersive Station image number 2
ORB X - Immersive Station image number 3
ORB X - Immersive Station image number 4
ORB X - Immersive Station image number 5
Where Luxury Meets Technology
ORB X is a fully immer sive multi-purpose semi-enclosed station which can fulfill diversified needs for work, entertainment, and gaming
€ 20.000,00
FULFILLING DIVERSIFIED NEEDS
... for work, entertainment, and gaming use while taking the immersive experience to the next level with futuristic design, craftsmanship and seamless hardware and software integration.
Audio
DYNAMIC SOUNDSTAGE
Immersive surround sound speakers to create true surround sound and an amazing spatial audio experience.
Shuttle Dome
ENHANCED PRIVACY
Semi enclosed design to keep away distractions and enables an uninterrupted privacy mode with the automated shuttle dome enclosure which can be engaged at the press of a button.
Adjustability
CUSTONIZED COMFORT
An ergonomic recliner with adjustable headrest, lumbar support, and seating positions provide advanced customized comfort even during long marathon sessions.
Design
A COOL FACTOR TO SHOW PERSONALITY
ARGB illumination surrounds the user with a wide variety of color arrangements to match the atmosphere or mood.
  • Product Number IXS-OX1-****-**-***
  • Exterior Color Universe Black
  • Exterior Color Arctic White
  • Voltage 100 ~ 240 VAC, 50 / 60 Hz
  • Power Support 1200 Watt for PC and monitors Power consumption 750 Watt max.
  • Monitor Mount Support up to three 27" monitors
  • Cockpit Material ABS
  • Ergonomic Recliner Material Genuine leather
  • Operating Temperature Range 5°C ~ 40°C (Space temperature)
  • Operating Humidity Range 5% ~ 95% RH
  • Load Limit Single-monitor: support up to 8kgs Suggested monitor size: 34» (curved & flat), Triple-monitor: support up to 18kgs Suggested monitor size: 3 * »27 (curved & flat)
  • Audio System 2.1-channel 60W masterAUDIO with power amplifier, optical fiber (S/PDIF) input 2pcs of 2”*2 full-range speakers 2pcs of 2” tweeter speakers 1pcs of 5” subwoofer
  • Lighting Effect ARGB LED strip with 8-mode effects, compatible w/ masterPLUS+ Software Audio to ARGB LED strip at base, audio input from 2.1 channel masterAUDIO subwoofer
  • USB-Hub 3 * USB-A 3.1 GEN1 5V/0.9A, 1 * USB-A 3.1 GEN1 5V/1.5A, 1 * USB-C 3.1 GEN1 5V/1.5A, 1 * USB-C 3.1 GEN1 w/ 60W PD
  • Weight 343.5 kgs
  • Dimensions (L x W x H) 1881 mm x 1810 mm x 2088 mm
  • Product Station
