MasterAccessory Riser Cable PCIe 4.0 x16 200mm V2 image number 0
MasterAccessory Riser Cable PCIe 4.0 x16 200mm V2 image number 1
MasterAccessory Riser Cable PCIe 4.0 x16 200mm V2 image number 2
MasterAccessory Riser Cable PCIe 4.0 x16 200mm V2 image number 3
MasterAccessory Riser Cable PCIe 4.0 x16 200mm V2 image number 4
Flex Your Graphics Muscle
PCIe 4.0 Compatible
Ultra Durable PCB
Heavy Duty Shielding
Gold-Plated Pin Connections
Protective ABS Casing
Ultra-Flexible Cable Sleeves
Price reduced from € 54,99 to € 24,99
AVAILABLE IN BOTH BLACK AND WHITE  COLORATIONS
FLEX YOUR GRAPHICS MUSCLE
Cooler Master's premium PCIe4.0 Riser Cables V2 are available in both BLACK and WHITE so you can choose the color that best matches your setup!
PCIE 4.0 COMPATIBLE
HEAVY DUTY SHIELDING
GOLD-PLATED PIN CONNECTIONS
NEW PROTECTIVE ABS CASING
NEW ULTRA-FLEXIBLE CABLE SLEEVES
FLEX YOUR GRAPHICS CARD MUSCLE
The Cooler Master Riser Cable PCIe 4.0 x16 V2 is designed for greater data transmission efficiency, maximum flexibility and durability. High quality plastics grant increased cable flexibility and strength for the tightest PCI card installations, while the heavy-duty shielding prevents electromagnetic interference from degrading signal quality.
The multi-layer coated PCB provides the best-in-class cable flex, moisture resistance and performance under high thermal loads.
  • Model Number MCA-U002R-KPCI40-200 (Black), MCA-U002R-WPCI40-200 (White)
  • Units per package 1 piece per package
  • Color(s) Black / White
  • Compatibility PCIe 4.0 and older
  • Component Materials PCBA, Silver Plated Copper Wire 30 AWG
  • Insulation Materials PE, TPE
  • Other Materials ABS, Nickel, Gold, PP, Brass, Silver
  • Connectors PCIe x16 Male to PCIe x16 90° Female
  • Cable Length 200mm
  • Contact Current Rating 1.1A per contact pin
  • Max Voltage Rating 30V
  • Working Voltage / Current DC 12V / 5A
  • Operating Temperature -20° to +100° Celsius
  • Warranty 1 year
  • Series Others
