Silencio S600 image number 0
Silencio S600 image number 1
Silencio S600 image number 2
Silencio S600 image number 3
Silencio S600 image number 4
Silencio S600 image number 5
Silencio S600 image number 6
Silencio S600 image number 7
Silencio S600 image number 8
Silencio S600 image number 9
Silencio S600 image number 10
Silencio S600 image number 11
Silencio S600 image number 12
Silencio S600 image number 13
Silencio S600 image number 14
Silencio S600 image number 15
Silencio S600 image number 16
Silencio S600 image number 17
Silencio S600 image number 18
Silencio S600 image number 19
Silencio S600 image number 20
Silencio S600 image number 21
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silence Has a Sequel
Silencio S600
Silencio Design
Silencio Technology
Sound Dampening Material
Top & Front Ventilation
Reversible Steel Door
  • In Stock
€ 129,99
Silencio Technology
Top
Ventilation
For an even higher demand for ventilation, the top panel’s Sound Dampening Cover can be removed for unrestricted ventilation. An optional dust filter for the top panel ventilation is included, allowing the top panel and front panel to work in conjunction to cool the system.
Ventilation
Silencio Fans
Silencio Fans
Motherboard Support
Mini-ITX, Micro-ATX, ATX
Cooling Support
Fan
Radiators
Top:
120 / 140mm x 2 Fans
120 / 240mm* Radiator
*remove ODD cage
35mm max motherboard component height
Front:
120 / 140 / 240 / 280 Radiator
Rear:
120 x 1 Fan
120 x 1 Radiator
Storage Support
5.25” ODD x 1 (ODD version)
3.5” HDD x 4
2.5” SSD x 5
Clearances
CPU Cooler (Steel): 167mm
CPU Cooler (TG): 166mm
Power Supply: 180mm
Graphics Card: 398mm
  • Model Number MCS-S600-KN5N-S00 (Steel), MCS-S600-KG5N-S00 (TG)
  • Color(s) Black
  • Materials - Body Steel, Plastic, Sound Absorbing Material
  • Materials - Side Panel Steel: Sound-Dampened Steel, TG: Left: Tempered Glass, Right: Sound-Dampened Steel
  • Dimensions (L x W x H) 478 x 209 x 470.5mm (Incl. Protrusions), 466 x 209 x 460.5mm (Excl. Protrusions)
  • Volume 44.8L (Excl. Protrusions)
  • Motherboard Support Mini-ITX, Micro-ATX, ATX
  • Expansion Slots 7
  • 5.25" Drive Bays 1
  • 3.5" Drive Bays 4
  • 2.5" Drive Bays 5
  • I/O Panel - USB Ports 2x USB 3.2 Gen 1 (formerly USB 3.0)
  • I/O Panel - SD Card Reader Supports SD & MMC Cards
  • Pre-installed Fans - Front 1x 120mm (PWM 800-1400 RPM)
  • Pre-installed Fans - Rear 1x 120mm (PWM 800-1400 RPM)
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Front 120 / 140 / 240 / 280mm
  • Radiator Support - Top 120mm / 240mm (remove ODD) (35mm max motherboard component height)
  • Clearance - CPU Cooler Steel: 167mm, TG: 166mm
  • Clearance - PSU 180mm
  • Clearance - GFX 398mm
  • Cable Routing 18-26mm
  • Size Mid Tower
  • Series Silencio Series
