Storm Controller image number 0
Storm Controller image number 1
Storm Controller image number 2
Storm Controller image number 3
Storm Controller image number 4
Storm Controller image number 5
Storm Controller image number 6
Storm Controller image number 7
Storm Controller image number 8
Storm Controller image number 9
Storm Controller image number 10
Storm Controller image number 11
Storm Controller image number 12
Storm Controller image number 13
Storm Controller image number 14
Storm Controller image number 15
Storm Controller image number 16
Storm Controller image number 17
Storm Controller image number 18
Storm Controller image number 19
Storm Controller image number 20
Storm Controller image number 21
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Storm Controller
Ergonomic Multi-Host Wireless Gaming Controller
Storm Controller
The Storm Controller is an extremely versatile controller with multi-device connectivity, 40-hour battery life, and an ergonomic hand-sculpted design to make it the next great addition to your gaming setup.
  • In Stock
€ 39,99
Multi-device Connectivity
Versatile Connectivity
With both wired and wireless connectivity options, you can use the controller in any situation you prefer. Enjoy the freedom and convenience of wireless play with Bluetooth connectivity, and switch connections at the press of a button. Alternatively, you can instantly connect using wired mode and charge the controller simultaneously through the USB-C port. The battery life offers up to 40 hours on a single charge, ensuring nonstop gaming sessions.
Anti-slip Halo Texture
Precision Trigger Force
Hybrid D-pad
Phone Cradle Attachment
With the optional phone cradle attachment, gaming anywhere is even more convenient and accessible. The cradle can be utilized in multiple angles and can be set on a desk or other objects for even more convenience. The phone cradle attachment also has an intuitive, easy-adjust system, allowing you to set-and-play the phone in any position you like with minimal hassle.
Learn More
Unique Identity
Unique Identity
The Storm Controller fully embraces our unique visual identity with a high-quality finish accompanied by purple accents and the Halo Logo in the center.
  • Product Number CMI-GSCX-BK1
  • Color Black
  • Position Mainstream
  • Connectivity Wireless (Bluetooth 5.0) & Wired via USB-C
  • Wireless Range 10m
  • Battery Capacity 1000mAh
  • Battery Life 40 hours
  • Rumble Support Haptic Feedback Dual Motors
  • Size 160 x 105 x 61 mm
  • Support Windows, iOS 15 & Android 5.0 and above
  • Warranty 1 year
  • Product Gaming Controller
  • Note The Cradle is optional
