Tempest GP27Q image number 0
Tempest GP27Q image number 1
Tempest GP27Q image number 2
Tempest GP27Q image number 3
Tempest GP27Q image number 4
Tempest GP27Q image number 5
Tempest GP27Q image number 6
Tempest GP27Q image number 7
Tempest GP27Q image number 8
Tempest GP27Q image number 9
Tempest GP27Q image number 10
Tempest GP27Q image number 11
Tempest GP27Q image number 12
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Tempest GP27Q
Visuals beyond limits
Tempest GP27Q
Experience truly immersive HDR performance like never before with the brand-new Tempest GP27Q MiniLED Monitor with 576 local dimming zones. Paired with a Quantum Dot WQHD resolution panel with an extremely fast 165Hz refresh rate, the GP27Q is the perfect next-level upgrade for your setup.
  • In Stock
€ 600,00
A True Work and Play Monitor
With specifications perfect for both the working professional as well as the hardcore gamer, the Tempest GP27Q is a true do-it-all monitor. Equipped with a 2560 x 1440 resolution panel that covers 98% of the DCI-P3 color spectrum, and boasts 165Hz refresh rate with a 1 ms response time, this monitor can be the perfect centerpiece to your work and play setup.
Deep Black Performance
Quantum Dot Visual Brilliance
Brightest Shine
Easy On The Eyes
Cutting Edge Speed
Stunning Clarity
Connection Master
Make It Your Game
Make It Your Game
Make It Your Game
Cooler Master Unique Design
Master Agility
With a wide range of adjustability, the Tempest GP27Q can be positioned to the way you want it exactly.
AMPLE Connectivity
2 x USB Type A
1 x Type B
2 x HDMI 2.0
1 x DisplayPort
1 x USB Type C (supports 90W PD charging output)
1 x 3.5mm Headphone Jack
  • Product Number CMI-GP27-FQS
  • Screen Size 27"
  • Ratio 16:9
  • Screen Type Flat Series
  • Panel Ultra-Speed IPS 1.07B colors w/Quantum Dot
  • Resolution 2K WQHD 2560x1440
  • Refresh Rate 165 Hz
  • Contrast Ratio 1000:1
  • Brightness 600 nits (SDR)
  • Brightness 1200 nits (HDR Peak)
  • DisplayHDR1000 Compatible
  • Color Gamut Adobe RGB 99%
  • Color Gamut DCI-P3 98%
  • I/O - DP 1
  • I/O - HDMI 2.0 2
  • I/O - USB Type C 1 (PD 90W + DP ALT + USB data)
  • I/O - USB 3.2 Type B 1
  • I/O - USB 3.2 Type A 2
  • I/O - Speaker 2 (3W)
  • Local Dimming MiniLED 576 zone
  • VRR Technology FreeSync Range: Yes
  • VRR Technology G-Sync Range: Yes
  • Response Time 1ms
  • Anti-flicker Yes
  • Overdrive Technology Yes
  • Power Consumption 39.5W*
  • Lighting Rear Cover Lighting
  • VESA 100x100 mm
  • Height Adjustment 0-110 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment ±15°
  • Pivot Adjustment 0° ±90°
  • Product Gaming Monitor
  • Monitor Series GP Series
  • Note * Measure a screen brightness of 200nits without audio/USB/Card reader connection.
