V SFX Gold 850 ATX 3.1 image number 0
V SFX Gold 850 ATX 3.1 image number 1
V SFX Gold 850 ATX 3.1 image number 2
V SFX Gold 850 ATX 3.1 image number 3
V SFX Gold 850 ATX 3.1 image number 4
V SFX Gold 850 ATX 3.1 image number 5
V SFX Gold 850 ATX 3.1 image number 6
V SFX Gold 850 ATX 3.1 image number 7
Small But Mighty
• Flexible compatibility
• 80 PLUS Gold certified
• Fully modular cabling
• 100% Japanese capacitors
• 10-year Warranty
region
€ 149,99 - € 162,99
Small But Mighty
As the leading SFX power supply design, the V SFX Gold offers a highly powerful unit in a space-saving, mini form factor.
Small But Mighty
Small But Mighty
ATX 3.1 support & a durable 90-degree 12V-2x6 cable
Includes ATX 3.1 support and a 90-degree 12+4pin (12V-2x6) PCIe 5.1 connector featuring higher electrical durability, lower temperatures, and improved safety.
The V SFX Gold is certified to achieve more
than 90% efficiency at typical loads.
Large, high-quality Japanese capacitors feature improved efficiency
and reduced ripple noise.
  • Model MPY-8501-SFHAGV-3E**
  • ATX Version ATX 3.1 & SFX 12V Ver. 3.42
  • Input Current 12-6A
  • Fan Size 92mm
  • Fan Bearing FDB
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time 16ms
  • Regulatory TUV, cTUVus, CE, BSMI, FCC, CCC, EAC, RCM, CB, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 4
  • 12V-2x6 Connectors 1
  • Series V SFX Series
  • 80 Plus Efficiency Gold
  • Form Factor SFX
  • Watts 850W
