V SFX Platinum 1300 230V image number 0
V SFX Platinum 1300 230V image number 1
V SFX Platinum 1300 230V image number 2
V SFX Platinum 1300 230V image number 3
V SFX Platinum 1300 230V image number 4
V SFX Platinum 1300 230V image number 5
V SFX Platinum 1300 230V image number 6
V SFX Platinum 1300 230V image number 7
V SFX Platinum 1300 230V image number 8
V SFX Platinum 1300 230V image number 9
V SFX Platinum 1300 230V image number 10
V SFX Platinum 1300 230V image number 11
V SFX Platinum 1300 230V image number 12
V SFX Platinum 1300 230V image number 13
An SFX Revolution
• High power density
• Advanced thermal performance
• 80 Plus Platinum efficiency
• Fully modular cabling
• 10-year warranty
  • In Stock
€ 389,99
Enhanced Dissipation
High Power Density
Adopting with the components miniaturization technology by the improvement of materials engineering, manufacturing process and leading thermal technology, the V SFX Platinum has achieved one of the highest power density, 53% more than V SFX Gold 850W power supply, in the small form factor.
Miniaturized But Solid
Crafted with flat copper wire on Choke of DC-DC, flat transformer piling and aluminum plate dissipation structure on full-bridge LLC, it can effectively achieve components miniaturization. Adopting with advanced manufacturing process, it simultaneously keeps miniaturized but solid.
100% Japanese capacitors
10 Year Warranty
Fully Modular Cabling
Modular cables reduce clutter, increase airflow, and improve overall efficiency and thermal performance.
  • Model MPZ-D001-SFBP-B**
  • Input Voltage 200-240V
  • Input Current 7.7A (Max.)
  • Fan Size 92mm
  • Fan Bearing FDB
  • Efficiency ≥ 94% @ Typical Load
  • 80 PLUS Rating 80 PLUS Platinum EU 230V
  • Hold Up Time ≥16ms at 60% Load
  • Regulatory TUV, cTUVus, CE, BSMI, FCC, CCC, EAC, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 3
  • 12VHPWR Connector 1
  • Series V SFX Series
  • 80 Plus Efficiency Platinum
  • Category Above 750W
  • Form Factor SFX
  • Watts 1300W
  • ATX Version ATX 3.0
  • Input Voltage Range 230V
