Less is More: It is time for the next innovation in CPU cooling: 3DHP
Heat pipes have been part of CPU cooling for decades. While materials and manufacturing have improved over time, the basic layout used in most air coolers has remained largely unchanged. As processors have evolved, that traditional approach has started to show its limits.
3DHP is Cooler Master’s response to those limits. Rather than simply increasing the number of heat pipes or relying on taller fin stacks, 3DHP focuses on how heat pipes are positioned, how they contact the base, and how heat is distributed through the cooler. The goal is consistent thermal behavior, lower noise and reliable performance under real system conditions.
This approach has now been independently tested by Cybenetics, confirming that 3DHP delivers balanced cooling performance with less noise and long-term reliability. Less really is more.
