Global Headquarters
The Intelligent Guardian
Automatically detects abnormal current, adjusts output in real time, and alerts users through LED indicators for safer, more stable power delivery.
Engineered with digital control IC to achieve precise digital tuning of PFC and LLC, improving the overall efficiency 3% higher than previous series.
Includes the same optimized cable configuration, designed for reliable performance and clean system builds.
Features an enhanced cable configuration to support higher power demands and advanced high-performance setups.
Equipped with the latest standard and 12V-2x6 output connector, ready for next-gen flagship graphics cards.
Engineered to achieve a lab-level noise control to deliver quiet power operation.
Protective coating that improves durability and safeguards components in harsh environments.
This unit comes with a standard limited manufacturing warranty of 10 years from the date of purchase.
