GD120 ARGB Gaming Desk image number 0
GD120 ARGB Gaming Desk image number 1
GD120 ARGB Gaming Desk image number 2
GD120 ARGB Gaming Desk image number 3
GD120 ARGB Gaming Desk image number 4
GD120 ARGB Gaming Desk image number 5
GD120 ARGB Gaming Desk image number 6
GD120 ARGB Gaming Desk image number 7
GD120 ARGB Gaming Desk image number 8
GD120 ARGB Gaming Desk image number 9
GD120 ARGB Gaming Desk image number 10
GD120 ARGB Gaming Desk image number 11
GD120 ARGB Gaming Desk image number 12
GD120 ARGB Gaming Desk image number 13
GD120 ARGB Gaming Desk image number 14
GD120 ARGB Gaming Desk image number 15
GD120 ARGB Gaming Desk image number 16
GD120 ARGB Gaming Desk image number 17
GD120 ARGB Gaming Desk image number 18
GD120 ARGB Gaming Desk image number 19
GD120 ARGB Gaming Desk image number 20
The Essential Core of Your Setup
A sturdy workhorse companion with built-in ambient ARGB lighting for those with a more limited work/play space. Whether you're looking to defeat your foes on the battlefield, or working on spreadsheets and work-related matters, the GD120 ARGB Gaming Desk has all the features you need.
  • In Stock
Price reduced from $399.99 to $129.99
A sturdy workhorse with built-in ambient ARGB lighting, perfect for those with limited workspace. Whether you're battling foes on the battlefield or tackling spreadsheets and work-related tasks, the GD120 ARGB Gaming Desk has all the features you need.
SMART AMBIENT LIGHTING
Control your ARGB lighting with the MasterPlus+ app. The GD120 ARGB can be synchronized with display colors, mimic monitor visual in real time as well as other Cooler Master products.
No More Tangled Wires
The rear steel tray on GD120 ARGB is designed to help keep your cables and adapters neatly organized and out of sight, contributing to a clutter-free workspace. With this effective cable management solution, you can enjoy a more streamlined and efficient setup, making cable organization and accessibility easier than ever before.
Comfortable Ergonomic Workstation
The GD120 ARGB is thoroughly tested for durability, being able to withstand up to 100kg without breaking a sweat. Rest easy with this battle-tested table as your sturdy companion.
Additional Mousepad Included
Outfit your workstation with the included 900 x 300 mm mousepad with an anti-slip rubber base. Using water repellent* materials and anti-fray stitching, it's a worthy companion to your desk for long extended game or work sessions.
*water resistance is only for cold liquids, hot liquids may still absorb into the mat.
See More GD Series Gaming Desk
  • Product Number CMI-GD120-PRA1
  • Position Upgraded Premium
  • Dimensions (Length x Width) 120 x 75 cm / 47.2" x 29.5"
  • Height Range 74 cm / 29.1"
  • Max. Load 100 kg / 220.5 lbs
  • Cable Management Tray Yes
  • Material Chipboard, Aluminum, Steel
  • Lighting ARGB (Front)
  • Software MasterPlus+
  • Compatibility Win 7, 8, 10, 11
  • Water-Resistant Mouse Mat Yes, 90 x 30 cm / 35.4" x 11.8"
  • Certification ANSI/BIFMA X5.5-2021, EN527-1, EN527-2, CE, FCC, RoHS, REACH, ISTA 3A (Package)
  • Product Gaming Desk
