MasterBox NR600 with ODD image number 0
MasterBox NR600 with ODD image number 1
MasterBox NR600 with ODD image number 2
MasterBox NR600 with ODD image number 3
MasterBox NR600 with ODD image number 4
MasterBox NR600 with ODD image number 5
MasterBox NR600 with ODD image number 6
MasterBox NR600 with ODD image number 7
MasterBox NR600 with ODD image number 8
MasterBox NR600 with ODD image number 9
MasterBox NR600 with ODD image number 10
MasterBox NR600 with ODD image number 11
FORM & FUNCTION STREAMLINED
Minimalistic Design
Seamless Tempered Glass
Ample Storage Support
Headset Jack
Fan Support
Radiator Support
Component Clearances
  • In Stock
buy PC case get discount 5%
$89.99
Streamlined, By Definition
Simplicity in aesthetics rarely reflect complexity in design. Cooler Master’s signature Fine Mesh spans the entire front panel for open airflow, makes up the structure of the case, and adds rigidity to its overall construction. Meticulously engineered for unhindered airflow, the MasterBox NR600 applies bold performance to a pure-and-simple design.
Minimalistic Design
Minimalistic Design
The MasterBox NR600 is a pure and simple design that is focused on airflow performance. A single-layer, fine mesh makes up the entire front panel, achieving efficient airflow while also acting as a dust filter.
The tempered glass side panel sits completely flush against the chassis, mounted securely and discreetly by a system of tabs and thumbscrews.
A total of 5 x 2.5" and 4 x 3.5" drives can be mounted using a tool-less system. Storage can be mounted on the PSU shroud, behind the motherboard tray, and in the HDD cage.
2.5"
3.5"
Headset Jack
Fan Support
Front: 140mm x2 / 120mm x3
Top: 140mm x2 / 120mm x2
Rear: 120mm x1
*non ODD version
Radiator Support
Front: 360/280/240/140/120mm
Top: 120/240mm
(35mm max motherboard component height)
Rear: 120mm
*non ODD version
  • Model Number MCB-NR600-KG5N-S00
  • Exterior Color Black
  • Materials - Body Steel, Plastic
  • Dimensions (L x W x H) 478 (L) x 209 (W) x 473 (H) mm
  • Motherboard Support Mini-ITX, Micro-ATX, ATX
  • Expansion Slots 7
  • 5.25" Drive Bays 1
  • 3.5" Drive Bays 4
  • 2.5" Drive Bays 5
  • Pre-installed Fans - Front 1x 120mm
  • Fan Support - Front 2x 120mm / 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Front 120 / 140 / 240 / 280mm
  • Radiator Support - Top 120mm/240mm (with ODD removed) (35mm max motherboard component height)
  • Clearance - CPU Cooler 166mm
  • Clearance - PSU 160mm
  • Clearance - GFX 410mm
  • Cable Routing - Behind Motherboard Tray 20-28mm / 0.78-1.10"
  • Dust Filters Top, Bottom
  • Size Mid Tower
  • Series MasterBox Series
