Mobius 120 image number 0
Mobius 120 image number 1
Mobius 120
Mobius 120
More Balance, More Burst
Mobius 120
Cooler Master is introducing the Mobius Series representing the performance line of fans with a new entry – Mobius 120.
  • In Stock
Price reduced from $19.99 to $14.99
 PERFECTING ENGINEERING
Cooler Master’s Mobius 120 is our new series of performance fans. With our enhanced Ring Blade Design, the Mobius Series optimizes both performance and acoustics, catering to a dynamic range of applications from case, liquid or air, to overclocking and intense gaming.
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
Pressure Acceleration Air Vents
Angled inner frame rim with chamfered side vents boost airflow draw, The structural ring blade eliminates any fan deformation- Ring Blade keeps the fan build structure rigid, inflexible, stiff and rigor
45 deg Q in and Q out, larger air flow in and air flow out increasing the Q
  • Product Number MFZ-M2NN-21NPK-R1
  • Exterior Color Black
  • Fan Profiles Non-LED
  • Fan Speed 0-2050 RPM ± 10%
  • Fan Airflow 63.1 CFM
  • Fan Noise Level 22.6 dBA
  • Fan Air Pressure 2.69 mmH2O
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.12A
  • Fan Safety Current 0.35A
  • Fan Power Consumption 1.44W
  • Fan Weight 179g / 0.38 lbs
  • Warranty 5 years
  • Cooler Type Case Fan
  • Series Mobius Series
  • LED Lighting Non-LED
