NR200P MAX image number 0
NR200P MAX image number 1
NR200P MAX image number 2
NR200P MAX image number 3
NR200P MAX image number 4
NR200P MAX image number 5
NR200P MAX image number 6
NR200P MAX
NR200P MAX
NR200P MAX
NR200P MAX
NR200P MAX
NR200P MAX
NR200P MAX
SFF Building Just Got Easier
NR200P MAX
The First of Cooler Master’s MAX Series
Cooler Master’s Expertise at Its Finest
SFF Building Refined
Luxurious Out-of-the-Box Solution
  • In Stock
null
The First of Cooler Master’s MAX Series; Cooler Master’s Expertise at Its Finest; SFF Building Refined Luxurious Out-of-the-Box Solution.
Customization
STREAMLINE YOUR BUILD EXPERIENCE
The pre-installed, pre-routed power supply and CPU-cooler
allows for ease of building and optimal cable & tubing management.
Install a motherboard, HDDs and finish off with a GPU:
No hassle, no routing. Stow away excess cables and you’re good to go.
Performance
Designed For High-End ITX Systems
Our Achievements
AWARDS
GPU panel
PATENTED QUICK INSTALL GPU PANEL
This exclusive, removable GPU panel design simplifies the process
of mounting large GPUs in SFF chassis, enabling greater hardware
support and hands-free installation.
Motherboard
EASILY ACCESSIBLE M.2 DRIVES
The motherboard tray is designed for unrestricted access to any m.2 drives installed behind the motherboard. The ventilated paneling ensures that m.2 storage drives installed in this location runs cool and reliably.
PREMIUM PCIE GEN4 RISER CABLE INCLUDED
NR200P MAX comes equipped with a premium shielded PCIe Gen4 Riser Cable to ensure both maximum compatibility and performance with all graphics cards.
Cooling Efficiency Beyond Compare
NR200P MAX’s built-in 280mm radiator boasts unmatched cooling efficiency owing to a 25% increase in aluminum fin surface area.
Compatible with a wide variety of Intel and AMD sockets (all brackets included), the AIO’s upgraded Gen3 dual-chamber pump is bound to keep any CPU running at optimum performance. Included Sickleflow 140 Non-LED fans utilize a two-tier sealing mechanism to prevent dust accumulation, resulting in longer serviceable life span and silent performance.
PSU Features
Performance Unbounded
The pre-installed, 80 Plus Gold efficiency PSU features 16AWG PCIe full-modular, high efficiency cables tailor-made to allow ease of installation without the hassle of cable management. Tailor-made to a small form factor, this PSU allows clearance for the largest, widest graphics cards while making the most of NR200P MAX’s 18 liter chassis.
Join The Discussion!
Got any feedback or future product requests? Or maybe you just want to chat with our product team. Join us our community on Discord and Reddit to talk directly to the designers of the products, or participate in feedback surveys, giveaways and more! We want to hear from you!
  • Product Number NR200P-MCNN85-SL0
  • Exterior Color Black / Grey
  • Materials - Exterior SGCC Steel
  • Materials - Left Side Panel Tempered Glass x1
  • Dimensions (L x W x H) 377 x 185 x 292mm (incl. Protrusions)
  • Volume 18.30L
  • Motherboard Support Mini-ITX
  • Expansion Slots 3
  • Drive Bays - 5.25" ODD 0
  • Drive Bays - 3.5" / 2.5" Combo 1
  • Drive Bays - 2.5" SSD 2 (Max. 3)
  • I/O Panel 2x USB 3.2 Gen 1 (USB 3.0)
  • Included Accessories 1x MasterAccessory Riser Cable PCIe 4.0 x16 - 35mm
  • Included CPU Cooling Solution 280mm radiator
  • Included Power Supply Unit V850 SFX Gold
  • Fan Support - Top 2 x 120mm / 2 x 140mm
  • Fan Support - Bottom 1 x 120mm (max 15mm, with 3.5" HDD at the bottom)
  • Radiator Support - Top 240mm / 280mm
  • Clearances - CPU Cooler 67mm
  • Clearances - Power Supply 130mm
  • Clearances - Graphics Card L: 336mm (incl. power connector)
  • Dust Filters Bottom
  • Power Supply Support SFX
  • Warranty 2 years (Case)
  • Warranty 2 years (Thermal Solution)
  • Power Supply Support SFX-L
  • Dust Filters Left
  • Clearances - Graphics Card H: 160mm (incl. power connector)
  • Fan Support - Bottom 2 x 120mm (max 15mm, w/o 3.5" HDD at the bottom)
  • Included CPU Cooling Solution 2 x 140mm SickleFlow PWM
  • I/O Panel 1x 3.5mm Headset Jack (Audio + Mic)
  • Drive Bays - 3.5" HDD 1 (Max. 2)
  • Motherboard Support Max. size: 170 x 180mm
  • Dimensions (L x W x H) 361 x 185 x 274mm (excl. Protrusions)
  • Materials - Left Side Panel Steel x1
  • Materials - Exterior Mesh
  • Materials - Exterior ABS Plastic
  • Included CPU Cooling Solution Gen 3 Cooler Master Pump / CPU Block
  • Clearances - Graphics Card W: 75mm (triple slot)
  • Dust Filters Right
  • Warranty 10 years (Power Delivery)
  • Size Mini ITX
  • Dust Filters Top Panels
