CF120 ARGB image number 0
CF120 ARGB image number 1
CF120 ARGB
CF120 ARGB
Quiet Colorful Cooling
CF120 ARGB
Air Balance Fan Blades
Noise Minimization
Addressable RGB Lighting
  • In Stock
Price reduced from $29.99 to $19.99
Air Balance
Fan Blades
The frame is constructed with reinforced PBT for stability, with air balance fan blades for high airflow and cooling performance
Noise
Minimization
The flexible mounting system is anti-resonance for noise minimization
Vibrant ARGB lighting to add the touch of color to your build, Compatible with major Motherboards.
  • Product Number R4-S2S-12AA-GP
  • Exterior Color Black
  • Fan Speed 1200 ± 200 RPM
  • Fan Airflow 47.65 CFM
  • Fan Noise Level 20 dBA
  • Fan Air Pressure 0.89 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Power Connector 3-Pin
  • Fan Rated Current 0.16A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.92W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.21A
  • Cooler Type Case Fan
  • Fan Size 120
  • Number of LEDs 8pcs
  • LED Lighting ARGB
