A71C image number 0
A71C image number 1
A71C image number 2
A71C image number 3
A71C image number 4
A71C
A71C
A71C
A71C
A71C
Support Socket AM4
A71C
Cooler Master A71C ARGB CPU Cooler features a direct contact copper core for efficient heat dissipation, and is compatible with AMD AM4 sockets.
  • In Stock
Price reduced from $29.99 to $24.99
Wide RPM range PWM fan with ARGB lightning
The ARGB fan is certified to sync with Motherboard RGB software or controlled by our controller. The wide speed range can be fine-tuned for maximum cooling performance or silent operation.
A71C
SUPPORT SOCKET AM4
Direct contact copper core
ADDRESSABLE
RGB CONTROLLER
With Included Addressable RGB Controller, You can choose your favorite color easily. It also support lighting RESET butten of Case.
  • Product Number RR-A71C-18PA-R1
  • CPU Socket AM4
  • Material Aluminum, Copper
  • Dimensions (L x W x H) 120 x 120 x 60 mm / 4.7 x 4.7 x 2.36 inch
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 38.99 CFM ± 10%
  • Fan Air Pressure 1.2 mmH2O
  • Fan Noise Level 24.9 dBA (Max)
  • Fan LED Addressable RGB
  • Fan MTTF 280,000 Hours
  • Fan L-10 Life 40,000 Hours
  • Fan Rated Current 0.12A
  • Fan Power Consumption 1.44W
  • Cooler Type Standard Cooler
