Intuitive ARGB Detection
Intuitive LED detection automatically provides default ARGB spectrum lighting or full ARGB customization via 3-pin header connection.
White Coated Heat Pipes
Wide Range Compatibility
Upgraded Installation Brackets
Street Fighter Top Cover
Clean White Finish
©CAPCOM CO., LTD. ALL RIGHTS RESERVED.
A polished top cover showing the exclusive collaboration with Street Fighter 6.
Redesigned brackets simplify installation on the latest available platforms
Compact 154mm height designed for wide chassis compatibility without sacrificing performance
