Caliber R3 Gaming Chair image number 0
Caliber R3 Gaming Chair image number 1
Caliber R3 Gaming Chair image number 2
Caliber R3 Gaming Chair image number 3
Caliber R3 Gaming Chair image number 4
Caliber R3 Gaming Chair image number 5
Caliber R3 Gaming Chair image number 6
Caliber R3 Gaming Chair image number 7
Caliber R3 Gaming Chair image number 8
Caliber R3 Gaming Chair image number 9
Caliber R3 Gaming Chair image number 10
Caliber R3 Gaming Chair image number 11
Caliber R3 Gaming Chair image number 12
Caliber R3 Gaming Chair image number 13
Caliber R3 Gaming Chair image number 14
Caliber R3 Gaming Chair image number 15
Caliber R3 Gaming Chair image number 16
Caliber R3 Gaming Chair image number 17
Caliber R3 Gaming Chair image number 18
Caliber R3 Gaming Chair image number 19
Caliber R3 Gaming Chair image number 20
Caliber R3 Gaming Chair image number 21
Caliber R3 Gaming Chair image number 22
Caliber R3 Gaming Chair image number 23
Caliber R3 Gaming Chair image number 24
Caliber R3 Gaming Chair image number 25
Caliber R3 Gaming Chair image number 26
Caliber R3 Gaming Chair image number 27
Caliber R3 Gaming Chair image number 28
Caliber R3 Gaming Chair image number 29
Caliber R3 Gaming Chair image number 30
Caliber R3 Gaming Chair image number 31
Caliber R3 Gaming Chair image number 32
Caliber R3 Gaming Chair image number 33
Caliber R3 Gaming Chair image number 34
Caliber R3 Gaming Chair image number 35
Legacy Continued
Continuing the legacy of the R2, the Caliber R3 offers improved comfort, ergonomics and a new stand out look.
  • In Stock
Price reduced from $299.99 to $99.99
Legacy Continued
Continuing the legacy of the Caliber R2 Gaming Chair, the Caliber R3 offers a a brand new design with improved comfort and ergonomics.
Legacy Continued
Legacy Continued
Choose Your Style
Caliber R3 is available in your choice of purple or black colorways.
Choose Your Style
Choose Your Style
All-Day Comfort
Caliber R3 features ultra-soft yet dense memory foam that dynamically contours around you for all-day comfort.
Enhanced Seat Base
Caliber R3's seat base has been upgraded from a 9cm thick seat base to a 10.5cm. Increasing the thickness provides enhanced support and durability, ensuring comfort and support for even longer work or play sessions.
Precision Class 4 Gas Lift
Caliber R3 uses the proven and tried Precision Class 4 Gas Lift for precise, reliable, height and lock adjustment.
2D Armrest
2D Armrest
Caliber R3 features an adjustable 2D armrest to provide support where you need it most.
  • Product Number Purple: CMI-GCR3-PR, Black: CMI-GCR3-BK
  • Color Purple, Black
  • Total Height Range 125.5-133.5 cm / 49.4"-52.6"
  • Backrest Height 82 cm / 32.3"
  • Backrest Width 58 cm / 22.8"
  • Armrest to Armrest 71 cm / 28.0"
  • Seat Width (including sides) 58 cm / 22.8"
  • Sitting Area 38 cm / 15.0"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 70 cm / 27.6"
  • Seat Thickness 10.5 cm / 4.1"
  • Armrest Adjustability 28.5-36.5 cm / 11.2"-14.4"
  • Floor to Seat Top 48-56 cm / 18.9"-22.0"
  • Height Adjustability 8 cm / 3.1"
  • Recline 90-180 degree
  • Armrest 2D
  • Headrest Ultra-comfortable memory foam
  • Lumbar Support Ultra-comfortable memory foam
  • Outer Material Perforated PU
  • Inner Material Backrest: cut foam, Seatbase: cold molded foam
  • Frame Material Steel
  • Base (leg) Steel
  • Caster 60 mm / 2.4"
  • Gas Lift Class 4
  • Max. Weight Load 150 kg / 330 lbs
  • Product Gaming Chair
  • Chair Type Caliber R3 Series
