Dyn X Actuator Mount image number 0
Dyn X Actuator Mount image number 1
Dyn X Actuator Mount image number 2
Dyn X Actuator Mount image number 3
Broad Compatibility
Works with most available actuators including Cooler Master, Sigma Integrale, D-BOX, and Qubic System.
Haptic Feedback
The Dyn X and actuator mounts were developed together to effectively provide immersive haptic feedback.
Electronic Mounting Tray
Includes a mounting tray for use with most available actuator controller boxes, such as those listed above.
Simple And Easy Installation
Both the actuator mounts and the electronic mounting tray quickly bolt onto the Dyn X frame.
  • In Stock
$399.99
