GM34-CWQ ARGB image number 0
GM34-CWQ ARGB image number 1
GM34-CWQ ARGB image number 2
GM34-CWQ ARGB image number 3
GM34-CWQ ARGB image number 4
GM34-CWQ ARGB image number 5
GM34-CWQ ARGB image number 6
GM34-CWQ ARGB image number 7
GM34-CWQ ARGB image number 8
GM34-CWQ ARGB image number 9
GM34-CWQ ARGB image number 10
GM34-CWQ ARGB image number 11
GM34-CWQ ARGB image number 12
GM34-CWQ ARGB image number 13
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
Feel the Immersion
GM34-CWQ ARGB
View your content with an entirely new level of immersion with our ultra-wide 34" curved monitor. With top-notch gaming specifications along with wide color gamut support, the GM34-CWQ ARGB monitor is the perfect centerpiece addition to your work and play setup.
  • In Stock
Price reduced from $499.99 to $439.99
CUSTOMIZED HDR MODES
After activating HDR, you can choose from three HDR modes: Standard, Game, and Movie. Standard HDR mode allows you to adjust R/G/B color values, as well as brightness and contrast to better suit your preferences. Game and Movie HDR modes have preset configurations to optimize the HDR viewing experience based on your content.
SPEED AND RELIABILITY
With a 144Hz refresh rate combined with an ultra-fast 0.5ms (MPRT) response time, your games will look clearer than ever before. Track enemies with precision and dominate the battlefield as your enemies struggle to keep up with your speed.
MASTERPLUS+
MASTERPLUS+
Using the MasterPlus+ app, you can fully customize the ARGB lighting built into the Halo stand. Set specific colors for certain occasions as well as synchronize lighting to your other compatible Cooler Master peripherals.
Download
TYPE C VERSATILITY
TYPE C VERSATILITY
A single USB Type C port is built into the monitor, providing up to 65W PD power output which can fully charge your devices such as a laptop or other USB C compatible devices. It also supports signal display out via DisplayPort 1.4, so you can charge and connect your laptop or device to an external display all through one USB C cable only.
Swivel: -15°~+15°
Height: 0~80mm
TILT: -5°~+15°
CLEAN & MINIMAL AESTHETIC
Whether you're at the office, or in your gaming cave, the GM34-CWQ ARGB has a clean design with minimal branding that can fit perfectly in any setup.
• Height: 0-80mm
• Swivel: -15°~+15°
• Tilt: -5°~+15°
AMPLE CONNECTIVITY AND I/O
Connect all your devices with the wide range of I/O ports consisting of:
• 1 x DisplayPort
• 2 x HDMI
• 1 x USB Type C (65W PD, DP1.4)
• 2 x USB Type A
• 2 x 5W built-in speakers
• 1 x 3.5mm headphone jack
  • Product Number CMI-GM34-CWQA
  • Curve 1500R
  • Ratio 21:9
  • Screen Size 34"
  • Panel VA 8bit w/ Quantum dot
  • Resolution UWQHD 3440x1440
  • Refresh Rate 144 Hz
  • Contrast Ratio 4000:1
  • Brightness 400 nits (Typical)
  • DisplayHDR400 Compatible
  • Color Gamut DCI-P3 98%
  • I/O - DP 1
  • I/O - HDMI 2.0 2
  • I/O - Speaker 2 (5W)
  • I/O - USB Type C 1 (PD 65W)
  • I/O - USB 3.0 Type B 1
  • I/O - USB 3.0 Type A 2
  • VRR Technology FreeSync Premium, FreeSync Range: Yes, G-Sync Range: Yes
  • Response Time 0.5ms (MPRT)
  • Anti-flicker Yes
  • Overdrive Technology Yes
  • Lighting ARGB
  • Power Consumption 31W (Typ.)**
  • VESA 100x100 mm
  • Height Adjustment 0-80 mm
  • Swivel Adjustment -15°~+15°
  • Tilt Adjustment -5°~+15°
  • Product Gaming Monitor
  • Monitor Series GM Series
  • Screen Type Curved Series
  • Note * All may vary by models and region. Specifications and features are subject to change without notice.
  • Note ** Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Panel Type VA
