GX III Gold 850 image number 0
GX III Gold 850 image number 1
GX III Gold 850 image number 2
GX III Gold 850 image number 3
GX III Gold 850 image number 4
GX III Gold 850 image number 5
GX III Gold 850 image number 6
GX III Gold 850 image number 7
GX III Gold 850
GX III Gold 850
GX III Gold 850
GX III Gold 850
GX III Gold 850
GX III Gold 850
GX III Gold 850
GX III Gold 850
GX III Gold 850
Innovative, streamlined design
ATX 3.0 support & a 90-degree 12VHPWR cable
Optimized and silent thermal performance
Titanium efficiency at light loads
Fully modular cabling
10-year warranty
regional
null
Feature
ATX 3.0 & 12VHPWR cable
Includes ATX 3.0 support and a 90-degree 12+4pin (12VHPWR) PCIe 5.0 connector featuring higher electrical durability, improved safety, and capable of bringing up to 450W to your GPU.
Feature
Optimized thermal performance
An anodic-coated heat sink keeps average temperatures 5℃ lower than a traditional heat sink for enhanced durability and a prolonged life span.
Feature
80 Plus Gold & Cybenetics Platinum certified efficiency
80 Plus Gold and Cybenetics Platinum certifications indicate achievement of more than 90% efficiency at typical loads. This Gold certified unit can also achieve Titanium level efficiency under general light load usage in a 115V test.
Feature
Silent fan performance with a zero-RPM mode
This unit has received a Cybenetics A- noise level certification and includes a smart thermal control mode that defaults to zero spin.
Feature
  • Model MPX-8503-AFAG
  • Input Current 10-5A
  • Fan Size 135mm
  • Fan Bearing HDB
  • Fan Speed 1900 RPM
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time >16ms
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 3
  • 12VHPWR Connector 1
  • Series GX Series
  • 80 Plus Efficiency Gold
  • Category Above 750W
  • Watts 850W
