MasterFan MF120 Halo² 3in1 image number 0
MasterFan MF120 Halo² 3in1 image number 1
MasterFan MF120 Halo² 3in1 image number 2
MasterFan MF120 Halo² 3in1 image number 3
MasterFan MF120 Halo² 3in1 image number 4
MasterFan MF120 Halo² 3in1 image number 5
A Dual New World
The MasterFan MF120 Halo² is our redesigned dual loop LED series fan, now available as a 3-in-1 pack, giving you triple the cooling power.
$59.99
A DUAL NEW WORLD
A DUAL NEW WORLD
The MasterFan MF120 Halo² is our redesigned dual loop LED series fan, now available as a 3-in-1 pack, giving you triple the cooling power. The MF120 features 10% larger fan blades for improved air flow and cooling performance. The frame has been designed with a hybrid structure that maintains stability without sacrificing operational real estate. An upgraded driver IC is also included for increased cooling performance and minimal fan noise, while the elegant dual loop LED design is maintained via addressable gen 2 RGB lighting that provides the ultimate customizable experience. Enter a dual new world with the the MasterFan MF120 Halo².
HYBRID FRAME DESIGN
A hybrid frame structure maintains stability without sacrificing fan blade size or performance.
LED CONTROLLER
UPGRADED DRIVER IC
An upgraded driver IC boosts cooling performance while minimizing fan noise.
  • Product Number MFL-B2DN-213P2-R2
  • Exterior Color Black
  • Fan Speed 0-2050 RPM ± 5%
  • Fan Airflow 51.88 CFM
  • Fan Noise Level 27 dBA
  • Fan Pressure 2.89 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.14A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.68W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.77A
  • Fan Weight 174g / 0.38 lbs
  • Cooler Type Case Fan
  • Series MasterFan
  • Fan Size 120
  • LED Lighting ARGB
