MasterFan MF120 Halo² image number 0
MasterFan MF120 Halo² image number 1
MasterFan MF120 Halo² image number 2
Bring On The Light
Cooler Master has redesigned our Dual Loop LED series fan to introduce the new MasterFan MF120 Halo².
$24.99
50% MORE LIGHTNING
VIBRANT ADDRESSABLE GEN 2 RGB
50% MORE LIGHTNING
Larger LED rings increase lighting by 50% for even more vibrant lighting.
HYBRID FRAME DESIGN
HYBRID FRAME DESIGN
Redesigned frame structure and corner dampers maintain stability without sacrificing fan blade area for better performance.
LARGER FAN BLADES
LARGER FAN BLADES
Air Balance fan blades increased by 10% in size deliver stronger air flow and cooling performance.
IMPROVED COOLING PERFORMANCE
Fine tuned P-Q Curve increase air flow and pressure while being even more quiet than its predecessor.
  • Product Number MFL-B2DN-21NP2-R2
  • Exterior Color Black
  • Fan Speed 0-2050 RPM ± 5%
  • Fan Airflow 51.88 CFM
  • Fan Noise Level 27 dBA
  • Fan Pressure 2.89 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.14A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.68W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.77A
  • Fan Weight 174g / 0.38 lbs
  • Cooler Type Case Fan
  • Series MasterFan
  • Fan Size 120
  • LED Lighting ARGB
  • Number of LEDs 24pcs
