Halo of Light
MasterFan MF140 Halo ARGB 140mm Case Fan
Cooler Master is introducing a new addition to the MasterFan Halo Series, the MF140 Halo. Featuring dual loop Addressable RGB lighting...
Select Styles for Availability
$19.99
$21.99
Fan Rated Voltage12 VDC
RGB Rated Voltage5 VDC
RGB Connector3-Pin
LED LightingARGB
Warranty2 years
Fan Power Connector4-Pin (PWM)
Number of LEDs24pcs
Fan MTTF160,000 Hours
Cooler TypeCase Fan
Fan Bearing TypeRifle Bearing
Fan Size140
Fan Noise Level6 - 30 dBA
Fan Safety Current0.4A
RGB Rated Current0.55A (0.8A Max)
NoteProducts manufactured after 1st June 2021 are Addressable Gen 2 RGB LEDs
Fan ProfilesAddressable Gen 2 RGB
Fan Power Consumption1.8W
Fan Rated Current0.15A
Fan Dimensions (L x W x H)140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
SeriesMasterFan
Fan Weight215g / 0.47 lbs
Fan Speed650-1500 RPM
Fan Air Pressure1.17 mmH₂O ± 10%
Fan Airflow55 CFM ± 10%
Product NumberMFL-B4DN-15NPA-R1
