MasterLiquid Core II Series image number 0
MasterLiquid Core II Series image number 1
MasterLiquid Core II Series image number 2
MasterLiquid Core II Series image number 3
360 Degrees of Cool
Dual Chamber Pump​
Innovative Design​
Easy Installation​
Universal Socket Support​
Optimum Tubing Length
$84.99
Innovative Design​
An infinity mirror pump cover design brings stylish lighting and a modern touch to your build​.
Dual chamber pump
Patented design
Improved Quality
Dual Chamber Pump​
Our patented dual chamber design delivers a compact cooler with efficient and reliable performance.
Optimum Tubing Length​
400 mm tubing allows for effortless cooler installation in any orientation.
Easy Installation​
Easy Installation​
With pre-installed fans, streamlined cabling, pre-applied thermal paste, and pre-mounted brackets, setup is quick, clean, and effortless.
Broad compatibility with both Intel and AMD CPU sockets​.
Pre-Applied CryoFuze Thermal Paste​
Tube Clips Included
  • Product Number MLW-D24M-A18PA-R1 (240 Black)
  • Product Number MLW-D24M-A18PA-RW (240 White)
  • Product Number MLW-D36M-A18PA-R1 (360 Black)
  • Product Number MLW-D36M-A18PA-RW (360 White)
  • Color Black / White
  • CPU Socket Intel® LGA 1851 / 1700 / 1200 / 1156 / 1155 / 1151 / 1150 Socket
  • Radiator Material Aluminum
  • Radiator Dimensions 240: 277 x 119.2 x 27.2 mm​ / 10.9 x 4.7 x 1.1 inch
  • Radiator Dimensions 360: 394 x 119.2 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • Pump Dimensions 84.5 x 78.5 x 59.4 mm​ / 3.3 x 3.1 x 2.3 inch
  • Pump Profiles Addressable RGB
  • Pump Speed 2800 ±10% RPM
  • Pump MTTF >35,000 Hours
  • Pump Rated Voltage 12 VDC
  • Fan Power Consumption 7.2 W
  • Tube Length 400 mm
  • Fan Dimensions (L x W x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
  • Fan LED Addressable RGB
  • Fan Quantity 240: 2 PCS
  • Fan Quantity 360: 3 PCS
  • Fan Speed 650-1750 RPM ± 10%
  • Fan Airflow 122.4 m³/h (71.9 CFM) (Max)
  • Fan MTTF >40,000 Hours
  • Fan Rated Current 0.26 A
  • Fan Safety Current 0.37 A
  • Fan Power Consumption 3.12W
  • Warranty 5 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid Lite
