Global Headquarters
Cooler Master’s MasterLiquidPL360 Flux is the new embodiment of enhanced performance cooling.
Low profile radiator with superior fin density coupled with performance fans dissipates heat rapidly.
Unique air balance fan featuring interconnecting blades specifically designed for the Flux Series. Strengthened structure provides better stability for steady high speed operation. Angled inner fan frame rim boosts air intake, with frame gap generating increased air pressure for improved cooling.
Dual loop pump ARGB with independent lighting customization showcases your visual creativity without sacrificing cooling capability.
High speed motor utilizing a ceramic bearing impeller forces balanced water flow to and from the radiator for ultimate efficiency of heat exchange.
Included Addressable Gen 2 RGB controller works with Cooler Master’s MasterPlus+ software to customize individual LED colors, effects, brightness and more – all from an intuitive, convenient interface.
