MK770 image number 0
MK770 image number 1
MK770 image number 2
MK770 image number 3
MK770 image number 4
MK770 image number 5
MK770 image number 6
MK770 image number 7
MK770
MK770
MK770
MK770
MK770
MK770
MK770
MK770
The Ultimate in Customization and Comfort
MK770
Introducing the Cooler Master MK770 Hybrid Wireless Keyboard, not merely a piece of technology, but a seamless extension of your essence. Immerse yourself in a world where comfort intertwines with innovation, where the boundaries between you and your device fade away.
switch
$79.99 - $95.99
Discover a realm where each keystroke feels just right. The Cooler Master MK770 Hybrid Wireless Keyboard is more than tech — it's a genuine extension of you. Whether you're battling in a game, crafting a story or designing tomorrow's masterpiece, the MK770 ensures every interaction is effortless. Dive deep into an experience where comfort meets innovation.
Battle Ready
Perfect for intense gaming sessions, the MK770 is built for the long haul. Reliable, programmable, durable and efficient— the MK770 Keyboard.
Comfort
Full Gasket Structure
The gasket structure reduces vibration and noise
contributing to a comfortable typing experience
Flexible Connectivity
Triple wireless lag-free connectivity requires minimal power
Customizable RGB
Free Master Control Software allows custom lighting modes and macros
Hot-Swappable Switches
Hot-Swappable mechanical switches allow easy customization
Helpful Features
Design
Helpful Features
Adjustable feet and dongle pocket are subtle add-ons that highlight the thoughtful design
Multi-Function Roller
Extra Functionalities
An innovative little feature that offers a lot of help.
  • Product Number Macaron: MK-770-MCKR1/W1/M1-**, Space Gray: MK-770-GKKR1/W1/M1-**
  • Keyboard Switch Type Kailh Box V2 Switch
  • Keyboard Keycaps PBT Double-shot Keycap (US/TC), ABS Paint & Laser-engraved Keycap (Other layout)
  • Layout ANSI: 98Key layout, ISO: 99Key layout
  • Keyboard Material ABS
  • Keyboard Color Macaron, Space Gray
  • Keyboard LED Color RGB, 16.7 million colors
  • Keyboard Polling Rate 1000Hz (Wired/2.4GHz Mode), 125Hz (Bluetooth Mode)
  • Keyboard Response Time 1ms
  • Keyboard On-board Memory 128 KB
  • Keyboard On-the-fly System Yes
  • Keyboard Multimedia Key Through Function Key (FN)
  • Connectivity Wired / 2.4GHz / Bluetooth 5.1
  • Charging Support Wired charging
  • Battery 4000mah
  • Compatible OS Windows 8+ / Mac OS X 10.10+ / Android / iOS
  • Software Support MasterPlus+ Support
  • Keyboard Connector Cable USB Type-C (Keyboard Side), USB 2.0 Type A (Computer Side)
  • Keyboard Cable 1.8m, USB Type-C Detachable & Coiled Braided
  • Keyboard Dimensions (L x W x H) Standard: 380.89 x 140.42 x 38.74 mm, Feet Open 1: 380.89 x 140.42 x 42.9 mm, Feet Open 2: 380.89 x 140.42 x 45.51 mm
  • Keyboard Weight 1052g / 2.319 lbs (without cable)
  • Product Keyboard
  • Serie MK Series
  • Keyboard Type Mechanical
