Motion 1 Haptic Gaming Chair image number 0
Motion 1 Haptic Gaming Chair image number 1
Motion 1 Haptic Gaming Chair image number 2
Motion 1 Haptic Gaming Chair image number 3
Motion 1 Haptic Gaming Chair image number 4
Motion 1 Haptic Gaming Chair image number 5
Motion 1 Haptic Gaming Chair image number 6
Motion 1 Haptic Gaming Chair image number 7
Motion 1 Haptic Gaming Chair image number 8
Motion 1 Haptic Gaming Chair image number 9
Motion 1 Haptic Gaming Chair image number 10
Motion 1 Haptic Gaming Chair image number 11
Motion 1 Haptic Gaming Chair image number 12
COMFORT / IMMERSION / REVOLUTION
Embrace the future of entertainment and experience the next level immersive haptic feedback. Motion 1, the award-winning haptic gaming chair, is set to redefine your home entertainment. With expert engineering, experience next-level immersion and unparalleled tactile feedback tailored for your favorite games and movies. Feel the thrill of bullets whizzing past or the exhilarating crash of ocean waves, and discover a whole new realm of realism.
  • In Stock
null
D-BOX CODED GAMING
The Tech That Powers Life-like Immersion. Discover why the D-BOX Coded Gaming experience is at the cutting edge of immersive technology. Brace yourself for the heart-pounding tension and exhilarating release of the Hunter's Bow as it gracefully expands and contracts in your hands. Feel the raw power of the crashing waves as they collide with your boat during daring raids. With Motion 1, Assassin's Creed Valhalla becomes an extraordinary journey, immersing you in a realm of unparalleled life-like immersion that was once deemed impossible.
D-BOX CODED VIDEO
Rewatch and experience your favorite movies like never before,
with D-BOX Coded Video on your Motion 1.
Feel the world around you disappear.
D-BOX Catalogue
2500+
GAMES AND MOVIES
Safety
Ergonomic comfort
Safety
Motion 1 has been tested to provide a safe and enjoyable haptic experience, passing multiple durability tests with up to 120 kg of weight. The custom Cast Aluminum wheelbase delivers a solid and sturdy base for years to come. For improved safety and the highest haptic settings, Motion 1 has lockable casters that provide enhanced stability and secure positioning.
Adjustments
Ergonomic comfort
Adjustments
Motion 1 features an extensive range of adjustments to achieve the ideal 90-degree angle from your knees to the ground. Crafted from 3D sculpted foam, Motion 1 has gone through rigorous testing by our designers and engineers. Every curve and contour is perfected to ensure optimal comfort, pressure distribution, and endurance during your immersive haptic sessions. Additionally, relax with Motion 1's 120 degrees of reclining, providing the perfect rest during your well- deserved breaks. The magnetic headrest and lumbar pillows add another layer of luxury and comfort, easily adjustable in height and effortlessly removable while adjustable armrests provide optimal positioning.
  • Product Number CMI-GCMT1-*****
  • Color Black
  • Total Height Range 122-127 cm / 48.0"-50.0"
  • Backrest Height 87 cm / 34.3"
  • Backrest Width 57.5 cm / 22.6"
  • Armrest to Armrest 71 cm / 28.0"
  • Seat Width (including sides) 58.4 cm / 23.0"
  • Sitting Area 48 cm / 18.9"
  • Seat Depth 53.5 cm / 21.0"
  • Diameter of Base 80 cm / 31.5"
  • Armrest Adjustability 23.5-27.5 cm / 9.3"-10.8"
  • Floor to Seat Top 45.5-50.5 cm / 17.9"-19.9"
  • Recline 90-120 degree
  • Height Adjustability 5 cm / 2"
  • Armrest Adjustable (up and down)
  • Headrest Magnetic ergo pillow
  • Lumbar Support Magnetic ergo lumbar support
  • Outer Material Eco-friendly fabric (Non-toxic polyester) on front and PU leather
  • Inner Material Cold molded foam
  • Frame Material Plywood and injected plastic
  • Base (leg) Aluminum
  • D-box haptic system Yes
  • Input Voltage Two verions: 1. 120V, 50/60 Hz, 2A , 2. 230V, 50/60 Hz, 1.1A (NOT switchable)
  • PC Connection USB 2.0 or higher
  • Power Cord Compatibility US, UK, EU, AU
  • Software MasterPlus+
  • Compatibility Win 7, 8, 10, 11
  • Max. Weight Load 120 kg / 265 lbs
  • Product Gaming Chair
  • Chair Type Motion Series
