null image number 0
null image number 1
null image number 2
null image number 3
null image number 4
null
null
null
null
null
BUILT TO LAST
MWE Gold 750 V3
• ATX 3.1 support & a durable 12V-2x6 cable
• Fully modular cabling
• 10-year warranty
Power
  • In Stock
$89.99
CERTIFIED EFFICIENCY
The GX II Gold is certified to achieve more than 90% efficiency at typical loads.
SEPARATED THERMAL TECHNOLOGIES
Separated thermal technologies provide improved thermal performance and a large, high-quality Japanese capacitor features reduced ripple noise and enhanced reliability.​
FULLY MODULAR CABLING
  • Model 750: MPX-7503-AFAG-2***
  • Input Current 10-5A
  • Fan Bearing HDB
  • Fan Speed 2500 RPM
  • 80 PLUS Rating 80 PLUS Gold
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 6
  • PCI-e 6+2 Pin Connectors 4
  • 12V-2x6 Connectors 1
  • Series MWE Gold Series
  • Category Above 750W
  • 80 Plus Efficiency Gold
  • Watts 750W
