Global Headquarters
CREATE IT YOUR WAY
Flatpack assembly
Fully modular design
Built-in vertical GPU mount
Full-sized specs, pint-sized body
Highly customizable
Accessory ecosystem
Features modular panels that simplify and streamline the usual case
prep process. Every panel is separately removable for easy maintenance.
Besides the clear eco-benefits, we believe flat-packing will provide a fun and satisfying build experience.
Welcome to the future of PC DIY.
The symmetric design allows you to switch the steel panel and the glass panel with each other for a non-transparent build.
An unprecedented level of customizability allows for full creative expression.
Fully express yourself with the multi-color Macaron edition. It includes two sets of extra panels, an extra handlebar, and two accessory hooks (only available on Macaron edition models). Mix and match the modular panels to create a case that is truly your own.
The side radiator mount has two positions, allowing you to install a 280mm radiator or provide your GPU with extra airflow.
Vertically mount your GPU with the included bracket. You can even adjust the distance from the side panel to maintain good airflow.
The Qube 500 comes with a living accessory ecosystem. A Gem mini cable manager and accessory hook are included (only available on Macaron edition models), and we have prepared some 3D-printable files for you to create your own accessories.
